Impeller bearing differences - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-29-2019, 10:30 PM Thread Starter
I have a 1332 Pro, model # 926500. I need a new impeller bearing. The part # is 05409300. I find prices all over the place for the same part. Should I just buy the least expensive one? Any differences?
Sent from my iPhone using Tapatalk Pro
BostonFJ40 is offline
post #2 of 10 Old 01-29-2019, 10:39 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 633
I sure as heck wouldn't buy the $80 version For our purposes, I suspect any sealed (shielded?) bearing would be good enough. This isn't a super-high-RPM, high-precision application. If the bottom one is an OEM bearing, and the cheapest, that would get my vote, assuming shipping is reasonable.
Thanks BostonFJ40 thanked for this post
Likes BostonFJ40 liked this post
post #3 of 10 Old 01-30-2019, 11:35 AM Thread Starter
The least expensive one is actually nearby so I can pick it up.
post #4 of 10 Old 01-30-2019, 11:43 AM
Thanks (Received): 112
Likes (Received): 293
You REALLY have to watch prices on Amazon. They use a ton of 3rd party vendors who offer stuff at outrageous prices, and usually along side identical items offered by either Amazon or other vendors are very reasonable prices. Check to see who is the supplier before buying on Amazon, sometimes its not all that clear as to who will be supplying. High prices, NO PRIME available, and high shipping charges for small items are good tipoffs that its a 3rd party.
Work fascinates me.
skutflut is offline
post #5 of 10 Old 01-30-2019, 11:58 AM
I continue to be amazed be the things that people will order online before checking local sources.
Rex
BjornToulouse is offline
post #6 of 10 Old 01-30-2019, 12:43 PM
db130's Avatar
Thanks (Given): 15
Thanks (Received): 64
Likes (Given): 205
Likes (Received): 139
If you look at the Ariens part number on repairclinic.com, you can see in the pic that the bearing is made by Peer with a part number of 8186-RSTLD.
I believe Stens also uses a similar Peer bearing for this application as well.
db130 is online now
post #7 of 10 Old 01-30-2019, 01:01 PM
Thanks (Received): 43
Likes (Received): 112
If you have a local NAPA store or Fastenal, even a Motion Industries they can normally cross the the bearing number stamped on the bearing and get you #s or the bearing from SKF, Timkin, Precision, National to mention a few. You can even do it online with a bearing cross and get you # then call and see if anyone has it in stock.
I like to do this as not all bearings are created equal....
Lottstodo is offline
post #8 of 10 Old 01-30-2019, 01:04 PM
gibbs296's Avatar
Thanks (Given): 134
Thanks (Received): 52
Likes (Given): 993
Likes (Received): 228
https://www.mtdparts.com/equipment/m...9300-504-01244 or..https://www.cubcadetpartsdistributor...arin-504-01244
gibbs296 is online now
post #9 of 10 Old 01-30-2019, 03:20 PM
Thanks (Received): 90
Likes (Given): 24
Likes (Received): 223
I bought one from Lowe's and only paid about $10. It was in the "Pik-a-nut" area. Yep - surprised me also !
RIT333 is online now
post #10 of 10 Old 01-30-2019, 07:32 PM
Thanks (Given): 56
Likes (Given): 52
Likes (Received): 155
both prices are a ripoff
MY VIDS ON FIXIN HER UP
vinnycom is offline
