Delixe 28 SHO Leaving Rows of Snow - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-30-2019, 01:01 PM Thread Starter
I purchased a Deluxe SHO in November of 2016. This was my very first snowblower but after living in the south for 20 years I knew I did not want to shovel all of the snow we get here. I definitely agree with many comments regarding the auto steer. This feature does not work as intended and is a workout for my arms as I try to get the blower to go straight. I keep my equipment well maintained so I will probably be dealing with the steering issue 10 years from now.
To address my original question. If we have more than 3 or 4 inches my blower leaves a small row of snow with each pass, much like I would call "corn rowing" with a lawnmower. Is this normal or is there any adjustment I can make to keep this from happening? So far my only solution is to take half rows and that makes the job take twice as long.
Sent from my SM-G955U using Tapatalk
Dee74 is online now
post #2 of 18 Old 01-30-2019, 01:12 PM
Thanks (Received): 44
Likes (Received): 113
I worked on one that did that , and found that the bracket from the bucket to the auger head was adjusted to the extreme left and had the left outer auger/screw almost touching the bucket side while the rt side was almost a 1/2 away.
It was the lft side doing this , so I loosened the bracket bolts on the bucket and re-centered the augers the same distance on each side/ clearance to bucket sides and tightened it all up and the customer reported that it no longer did this.
May help for yours..
Lottstodo is offline
Likes Bondo 287, Kiss4aFrog liked this post
post #3 of 18 Old 01-30-2019, 01:52 PM Thread Starter
Thanks, I will look at this when the temps get above zero here.
Sent from my iPad using Tapatalk
Dee74 is online now
post #4 of 18 Old 01-30-2019, 10:42 PM
WVguy's Avatar
Thanks (Received): 40
Likes (Received): 158
Regarding the auto-turn giving you an upper body workout, some people have said that using the non-abrasive (i.e., "plastic") skids have successfully addressed that problem. You can buy them directly from Ariens or Jack's Small Engines has them cheaper. Others have found them at either Home Depot or Lowes, might save you time if one is local and you're in a hurry.
There are also aftermarket skids that may work better for you too. The ones below are the Ariens ones.
https://www.jackssmallengines.com/ja...riens/72603100
WVguy is offline
post #5 of 18 Old 01-31-2019, 07:35 AM
Thanks (Given): 135
Thanks (Received): 297
Likes (Given): 397
Likes (Received): 713
My Ariens is a 24", but it does this sometimes. As best I can figure out, it just isn't processing & flinging enough snow per second, even though the engine isn't slowing down.
I either:
- slow down (no fun)
- take a narrower cut (also not ideal)
or
- take a full cut, and leave some overflow behind. Then I go back and make cleanup passes in 6th gear.
Though this seems inefficient, the last one seems quickest to me.
To ask the basics, is it always on the same side of the machine? Are your auger shear pins all intact, so that the augers are locked to the shaft? If you broke 1 shear pin, you'd be likely to get this problem on one side of the machine.
post #6 of 18 Old 01-31-2019, 08:18 AM Thread Starter
The Home Depot here has the plastic skids for sale for the same price as Jack’s. I may need to try the out.
Dee74 is online now
post #7 of 18 Old 01-31-2019, 08:20 AM Thread Starter
I either:
or
I usually do the 6th gear cleanup lap. The first thing I checked was the shear pins, everything is intact and spinning.
Dee74 is online now
post #8 of 18 Old 01-31-2019, 08:41 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 220
Slow speed down, take a bite of 3/4 bucket or less. Check shear pins, both augers are spinning, check height of scraper bar and skids.
russ01915 is online now
post #9 of 18 Old 01-31-2019, 10:52 AM
As far as the auto turn workout goes here is a few things to check on your machine
1) tire air pressure , it has to be the same in both tires.
2) Set up squareness, You can do this on concrete if you know that it is completely flat and level.
I do this on a 1/2 sheet of plywood. make sure tires ( aired up) and bucket are on the plywood. Loosen the skids and pick them up to where only the scraper blade is resting on the wood. Loosen the 4 bolts- 2 per side ( 1 full turn donot remove!!!) that hold the blower housing to the drive assy. Now tip the unit back using down pressure on the handle bars and then let it back down gently to come to rest on the scraper blade, ( do not drop it or pick up on the handles just let it easily come to rest) now tighten the 4 bolts. This puts the machine in square.
With the blower still on the plywood insert a strip of wood under the scraper blade that is the thickness that you want to set your skid height at ( ie; 1/4' or 3/8" etc. like mine now is set for 3/4 as I have a gravel drive ) then lower your skids to meet the plywood keeping them flat against the wood an tighten the bolts good so the stay adjusted and it is done.
3) keep in mind that if the scraper blade is set so low that it can grab objects on one side or the other (like I mention gravel drive) it will try to turn the that side. that is why I run mine a little higher, and it is a lot easier. I keep a few different thickness of of wood handy just so I can adjust the skids to the driveway base and weather conditions.
Hope this helps
Likes Bondo 287, Mavaholic liked this post
post #10 of 18 Old 01-31-2019, 10:54 PM Thread Starter
This happens even in the slowest speed. Taking half buckets helps but just takes more time. Shear pins are good, augers are spinning, scraper bar set at 3/8” on asphalt driveway.
Dee74 is online now
