Belt running off Attachment Idler Pulley - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 01-30-2019, 04:53 PM Thread Starter
Cutter's Avatar
Thanks (Received): 11
Likes (Given): 116
Likes (Received): 119
I hope some of you can offer some advice.
After blowing snow on the weekend, it seemed like my blower was making a bit of a strange noise, and it seemed to vibrate a bit more than usual. I ziptied the auger handle and checked the augers running. The gearbox has a bit of a wobble ( not sure if that's normal), and when running the unit with the belt cover off, I noticed the auger belt closest to the engine block was running about 1/8 off the rear of the idler pulley. Is this pulley adjustable? is this a problem? It an Ariens 921037 that I bought from a JD dealership who used it for demos,etc. It has warranty on it, even though it was used but never sold.
Life is short, so if you don't have the strength to laugh at yourself,
call me.....I'll laugh at you!
2014 Ariens Deluxe 28 with 291 CC Engine
2011 John Deere JS36 Self Propelled Mower
Too many Craftsman Mechanic/Yard tools to mention
Cutter is offline
post #2 of 20 Old 01-30-2019, 05:12 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 72
Likes (Received): 434
Choice - Bring it back to the dealer or move the belt back on, if it moves again bend the idler bracket a little to move the belt back on. You may be able to put washers behind the bracket moving the idler pulley outward. If it has an adjustment it would move the idler pulley only in and out, not back and forth.
JLawrence08648 is offline
post #3 of 20 Old 01-30-2019, 06:25 PM Thread Starter
Cutter's Avatar
Likes (Given): 116
Thanks for the help. I might try bending it a bit. It's probably ok, but I am picky about my stuff working the way they are meant to.
The washer is also a viable option too. If nothing else....always the dealership.
Cutter is offline
post #4 of 20 Old 01-30-2019, 06:51 PM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 120
SimplicitySolid22 is offline
Thanks Cutter thanked for this post
Likes Cutter liked this post
post #5 of 20 Old 02-01-2019, 05:49 AM Thread Starter
Cutter's Avatar
Likes (Given): 116
Picture to show my issue
I took this yesterday to illustrate my issue.
Cutter is offline
post #6 of 20 Old 02-01-2019, 09:54 AM
The idler pulley with the spring looks shined up on the side toward the engine. That would suggest to me that something is loose or bent. The back of the belt should ride in the center only.
It could be the angle that the picture was taken, but the double belts don't look to be riding on the idler right either. It almost looks like the bucket would be tilted forward.
strtch5881 is online now
post #7 of 20 Old 02-01-2019, 10:36 AM
The more I think about it, the more I think that instead of a demo, it may have been a return. Where the bucket mounts to the frame may not be square and plumb.
post #8 of 20 Old 02-01-2019, 06:41 PM Thread Starter
Cutter's Avatar
Likes (Given): 116
Well, you may be right on both counts. It may well have been a return, probably will never know. I did buy it for about half price, so it was a good deal, and it does actually work well. I'm just a fussy guy. Today I took the bucket right off, checked the belts and the auger pulley. Also tightened the idler pulley and cleaned the inside. Checked the connection between the bucket and the tractor, and adjusted. Nothing made a difference, the belts are still
running just at the edge of the idler pulley. I left the beltcover off, started it and ziptied the auger handle down and noticed that the auger pulley on the bucket vibrated quite a bit. Bearing was tight. Maybe out of round pulley?
Cutter is offline
post #9 of 20 Old 02-01-2019, 08:32 PM
Possible pulley problem. At this point it could also be a bent shaft. Maybe it was dropped. You would need to check for runout with a dial indicator. When you had the bucket off, did you check both mating surfaces to see if they were flat and square?
post #10 of 20 Old 02-02-2019, 05:31 AM Thread Starter
Cutter's Avatar
Likes (Given): 116
Yes, they seemed to be square. I am going to remove the bucket again this weekend, and have another look at the whole machine. The more I think about what you said about a return, the more I think you're right.
Cutter is offline
