ST824LE Auger froze up - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 01-31-2019, 07:02 PM Thread Starter
Hi all, first timer on these boards. My blower worked great last week. Went to use it the other day, and when I engage the auger, I hear the belts squealing and nothing rotates. I am unable to rotate the auger by hand also. Was hoping to get some guidance as what the issue may be. If i take it to the shop it's at least a 2 week wait. Thanks for any help.
ID:	152719   Click image for larger version
ID:	152721   Click image for larger version
elctrcn9 is offline
post #2 of 16 Old 01-31-2019, 07:35 PM
Thanks (Given): 49
Thanks (Received): 8
Likes (Received): 7
Could be ice, but by looks of your photo maybe not. You could try to split the lower off the tractor, remove the belts and try to turn the the impeller and the auger. Years ago I got a piece of gravel between the bucket and the auger Ariens shear pins did not shear and I took out the gears in the auger assembly. Also check the engagement lever the way it pushes the belt down tight. Is the roller good, is the spring on and the arm sitting in the right place, are the belts toast?
Just some ideas.
If it does not turn with the belts off...Ö look to see in the gear box if the roll pin dropped out see photo if I can upload??
I marked in green.
Good luck
ron3033
ron3033 is offline
Thanks elctrcn9 thanked for this post
post #3 of 16 Old 01-31-2019, 07:38 PM
Likes (Received): 15
Check whether the impeller is literally frozen to the drum.
cpchriste is online now
post #4 of 16 Old 01-31-2019, 08:05 PM
Thanks (Received): 7
Likes (Received): 11
Would a space heater right in front of the auger help? I'd place a karosene heater right in front for an hour.
Xilbus is online now
post #5 of 16 Old 01-31-2019, 08:18 PM
Thanks (Given): 95
Thanks (Received): 191
Likes (Given): 72
Likes (Received): 434
Remove the belt cover and remove the shear pins then see.
Likes Bondo 287 liked this post
post #6 of 16 Old 01-31-2019, 08:21 PM
Hanky's Avatar
Thanks (Given): 109
Thanks (Received): 78
Likes (Given): 348
Likes (Received): 154
Also cover with a heavy tarp or sleeping bag to keep heat in may take hr or longer to unfreeze, I would guess that ice is built up behind the impeller from blowing wet snow. My self after blowing wet snow I pour a bucket of warm or hot water down the chute then run blower for a minute lift blower up by handle bars for a minute and all water is gone. Ask me how I know 30 years ago I did the same thing my craftsman froze up
Hanky is online now
post #7 of 16 Old 01-31-2019, 08:58 PM Thread Starter
Thanks for the tips guys. Iíll be trying these out and see whatís going on. Need to wait a couple days. Been insanely cold here. -50ís wind chill.
elctrcn9 is offline
post #8 of 16 Old 02-01-2019, 03:04 PM
I've never had this issue with my Ariens blowers but my Snappers ALWAYS froze if I left anything in the bucket. I used to keep a heat gun handy and point it down the chute if it froze.
The best way I found to prevent it was to put something under the wheels so that the whole unit tipped forward and water drained out. I had a customer with a Toro that did the same thing, jacking the wheels stopped it for them as well.
You will probably have to replace the belt if it heated up. It doesn't take much to damage them if the impeller is frozen, been there, done that.
stanz is offline
post #9 of 16 Old 02-01-2019, 04:26 PM
Thanks (Given): 95
Likes (Given): 72
Put a block of 2x10 under the wheels, or double it up to drain the water from the auger housing as you are calling it quits.
post #10 of 16 Old 02-01-2019, 08:19 PM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
I just went thru this. Save yourself some major time possibly.. see if the auger gear case is out of oil. If it is.. you MIGHT get lucky by re-filling it (80W90 Gear oil will work) It worked in the case of one of my church ST1032s.. I got VERY lucky..
GoBlowSnow is offline
