13 year old Ariens Pro-32 - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-02-2019, 11:41 PM Thread Starter
GoBlowSnow's Avatar
Likes (Given): 57
Likes (Received): 262
How much would you pay for one of these big monsters in good condition that had been gone over by a good mechanic? By good condition I mean no rust, scraper, bucket, skids all in good shape, engine running smooth, throwing snow nicely, new battery, drive is good. Paint is good.
https://iowafarmandlawn.com/showroom...c44306f7297a2/
ID:	152855   Click image for larger version
ID:	152857   Click image for larger version
ID:	152859   Click image for larger version
GoBlowSnow is offline
post #2 of 12 Old 02-03-2019, 04:09 AM
Thanks (Received): 25
Likes (Received): 31
There are a handful of issues on that vintage that bother me. The chute lock is temperamental and the original cable was prone to failure. Ariens made an update kit for about $40 that upgrades the cable and reduces the wear on the interlock. The original cable is a stiff plastic sleeve, the upgraded one has a metal shield with a rubberized covering.
The second issue is that the axle isnt ball bearing, it runs through a couple of flanges and someone at Ariens thought nylon bushings would make a great wear surface (they don't) so they are prone to wearing out. Doesn't seem to cause any issues other than about 1/16" of axle slop.
Ariens also released a pinion shaft anti-rotation kit for that series so see if its been installed. Its a plate and a hitch pin that gets installed on the left hand side behind the wheel. If you just see some bolt threads sticking out then it hasn't had a kit installed. The kit is easy to install and is actually covered under a mandatory recall. Without it the original hitch pin can come out allowing the shaft to rotate and wear into the frame. You'd have to put some high miles on it for that to happen though even without the kit.
Lastly when the 926s came out they had major problems with premature belt rotting (supplier issue-long since resolved) and alignment. They switched to a more aggressive (grippy) belt for the drive that solved most of the jumping problems and released a dual belt upgrade kit for the auger to reduce wear so i'd look for it. If its still a single auger belt i'd recommend upgrading it at some point. That kit is about $60 but comes complete with a new auger cable, pulleys and two new belts.
Other than that they're decent machines. Selling points are the key start and the biggest engine Tecumseh made for walk behind snow blower use. Price-well in a perfect world, if it has no rust, i'd say its worth as much as a grand. Most people would probably expect to pay less than half of that because its "old".
SnoThro is offline
Likes Bondo 287, classiccat liked this post
post #3 of 12 Old 02-03-2019, 05:15 AM
gibbs296's Avatar
Thanks (Given): 135
Thanks (Received): 55
Likes (Given): 1022
Likes (Received): 238
It looks like an OPE graveyard in the background. Not a fan of buying items left out in the elements 24\7 365.
gibbs296 is online now
Likes Bondo 287 liked this post
post #4 of 12 Old 02-03-2019, 08:57 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 105
Likes (Received): 218
I sold one that I had last year year for $1,100, in perfect shape. I personally wouldn't go more than $750.00 if perfect. $500 if not perfect.
russ01915 is online now
Likes Bondo 287, 1132le liked this post
post #5 of 12 Old 02-03-2019, 11:49 AM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 634
It looks like the inside of the chute has been painted black, maybe dealing with worn paint.
For around here, I think the $500-750 range would be reasonable. It looks to me like it's in good shape overall, even with the chute being painted.
post #6 of 12 Old 02-03-2019, 12:03 PM
1132le's Avatar
Thanks (Given): 30
Thanks (Received): 89
Likes (Given): 63
Likes (Received): 203
650 would not even buy one after using auto turn
It's a 345 lb monster I had the 1332
1132le is online now
Likes russ01915 liked this post
post #7 of 12 Old 02-03-2019, 12:47 PM
Thanks (Given): 19
Likes (Given): 105
I agree, the auto turn makes a world of difference on machines of this size.
post #8 of 12 Old 02-03-2019, 09:10 PM
The machine in the OP has a differential drive. It will pivot steer.
SnoThro is offline
post #9 of 12 Old 02-04-2019, 12:09 AM
1132le's Avatar
Thanks (Given): 30
Likes (Given): 63
did you see i said i had one
its a bear to steer
carry on
post #10 of 12 Old 02-04-2019, 12:24 AM
Sorry, hard to understand when there is no punctuation.
Were you having problems hitting snow with the machine trying to turn itself or just in general?
SnoThro is offline
