Carb jet cleaning - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 02-04-2019, 05:31 PM Thread Starter
Thanks (Received): 7
Likes (Received): 11
Carb jet cleaning
Hi guys, I felt the engine on my ariens surging a bit so I decided to do a bit of maintenance this afternoon.
I 1st turned the fuel shut off valve and let the engine run dry.
Removed the choke nob. Removed the carb cover and proceeded to remove both jets. The idle or pilot jet has a tiny black plastic cover that needs to be removed 1st. The idle jet's main hole was blocked and I also removed gunk from the small hole on the main jet.
Just doing this really helped get the engine back to a stable idle and high.
ID:	152907   Click image for larger version
ID:	152909   Click image for larger version
ID:	152911   Click image for larger version
ID:	152913   Click image for larger version
Xilbus is online now
Likes rod330 liked this post
