Ariens 924044 10 Hp - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-05-2019, 09:16 AM Thread Starter
Ariens 924044 10 Hp
I am trying to find snowblower dimensions for this machine as I would like to see if it will fit in my sport utility. I know it is very large.
Anyone know overall length, height at handlebars and at the engine and width (assuming the 32" width"?
xznk7n is offline
post #2 of 10 Old 02-06-2019, 02:21 AM
Thanks (Given): 40
Likes (Given): 46
Likes (Received): 191
Xznk7n, just saw your post....
I'll get dimensions tomorrow and post up my results for you.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #3 of 10 Old 02-06-2019, 06:26 AM
Likes (Given): 21
Rather than try to fit it in your suv, recruit a friend with a truck, or borrow or rent a trailer. Trying to stuff a snowblower that large into a suv can damage your vehicle, not to mention, injure the people trying to stuff it into a confined space.
strtch5881 is online now
post #4 of 10 Old 02-06-2019, 09:22 AM Thread Starter
Thank you! I put an 8 hp (924026) into the car a few weeks ago without too much trouble. I think they are similar size with similar dimensions but I am not sure. I contacted Ariens but they could not help.
xznk7n is offline
post #5 of 10 Old 02-06-2019, 09:09 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 235
I hauled a 10,000 series in a 1st gen BMW X5 once by folding down the rear seats, unbolting the attachment, then loading them separately.
The key was making sure it was drained of gas and propping up the tractor handlebars to keep it as level as possible. I then used a couple tie-down straps to keep it in place.
Worked perfect. Make sure though you got help both loading and unloading. It's a two man job for most mere mortals.
tlshawks is offline
post #6 of 10 Old 02-07-2019, 02:28 AM
Thanks (Given): 40
Likes (Given): 46
Rough measurements......
36" high at the handles with the levers squeezed.....
32 1/2" wide at the bucket .... then add extra depending on what type of shoes it has on it.
34" from front of bucket to rear of the tire.....
60" from front of bucket to end of handles.....
Hope this helps you with your quest !!!
I have a custom 924044 myself and it is my favorite machine, I've built a 36" beast and I'm still tweaking my 24" SHO machine. I love ariens machines, still can get parts for these older units. My machines will be handed down to my grandkids, for another 50 year run !!!!
~~ And Lastly ~~
Likes cranman liked this post
post #7 of 10 Old 02-07-2019, 08:39 AM Thread Starter
Thank you very much. This is helpful. I live in Michigan and I am driving to the upper peninsula to pick up this machine. Not wanting to tow a trailer through what are customarily tough road conditions.
xznk7n is offline
post #8 of 10 Old 02-07-2019, 08:40 AM Thread Starter
Smile Thank you!
xznk7n is offline
post #9 of 10 Old 02-07-2019, 08:49 AM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
I have a 2005 Toyota Rav4 and have had a couple 8hp, one was very long, in there. The key is handles in first. On some the handles can be removed, and you can always remove the auger housing.
post #10 of 10 Old 02-09-2019, 02:45 PM
Likes (Given): 7
I haul mine quite often & run it up some ramps,in low gear it walks right up.probably take the chute off first & it will fit & put the back seats down.
2)Ariens 1032
Old Monkey Ward 724
JD 828
Ariens 524
Plan on flipping the smaller ones,next snow!
sewman is offline
