Starts runs stalls out even choked. - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 02-07-2019, 01:42 PM Thread Starter
Likes (Received): 12
My 2004 824 always ran quite well. First third of the season it didnít wanna start took the car bought took it apart cleaned it didnít find anything wrong. Put it back together ran OK for a while plowed twice and it started acting up again recently
It starts fine thereís gas in the float bowl but itíll stall out shortly after running pretty well for about 15/2o seconds. Doesnít lik to run off full choke and even dies there or on. Half
Choke. The I pulled the primer line off the carburetor. Air puffs out but of I plignthe rubber hose and push it in it wonít hold air. No damage showing on the red rubber lik cracks ect. Any brilliant observations on this. Fresh nobooze gas has spark......
2002 Ariens 932-101
driz is online now
post #2 of 6 Old 02-07-2019, 02:20 PM Thread Starter
Oh I found it. GAS CAP. It fell off plowing and I found it. Too bad the inner liner piece is gone. All I have is a plastic pin sutcking up with a small square of foam stuck through the middle. I donít see how whatever was there an currently on a snowbank someplace , allowed air in to replace the fuel draining down but it does . Itís definitely sir locking though .
Iím half tempted to drill the top side of the cap above the threads and call it good if itís gonna cast more than a few bucks.
2002 Ariens 932-101
driz is online now
post #3 of 6 Old 02-07-2019, 03:02 PM
Thanks (Received): 44
Likes (Received): 113
That cap as it vents and replaces air also keeps gas vapor inside of the tank and debris out. water etc can easily come through a drilled hole, as well with gas vapor escaping your fuel is degrading even with stabil or similar product it does not protect open to air fuel evaporation or degradation.
That cap could end up being pretty cheap as opposed to other possible problems.
If the blower is stored in the garage, escaping fumes are not a good thing.
Lottstodo is offline
post #4 of 6 Old 02-07-2019, 04:34 PM
Likes (Received): 43
The disc that is missing from your cap may be in the tank. A new cap is inexpensive.
strtch5881 is online now
post #5 of 6 Old 02-07-2019, 04:50 PM
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
Same thing happened to me last year. A defective cap won't vent and acts like a vacuum lock and prevents the fuel from flowing into the system. Kind of like when you hold one end of a straw with your finger and the soda stays inside the straw. The replacement cap only cost about $10 and the problem was solved.
Dannoman is offline
post #6 of 6 Old 02-07-2019, 06:20 PM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
I learned the same thing. Donnyboy did a video on it. Here ya go
GoBlowSnow is offline
Similar Threads
Old snowblower runs great, then after 1/2 an hour gasps and stalls. Jdam00 Snowblower Repairs and Maintenance Forum 15 02-02-2015 05:36 PM
Engine needs to be choked out the longer it runs chapel Snowblower Repairs and Maintenance Forum 6 01-30-2015 10:39 PM
Cub Cadet only runs when choked orthoman52 Snowblower Repairs and Maintenance Forum 5 01-28-2015 05:43 AM
Craftsman stalls, starts slow cs42778 Craftsman Snowblowers 19 11-26-2014 04:19 PM
old 1962 Ariens 10M-L35 starts and runs 30 years later greatwhitebuffalo Ariens Snowblowers 4 08-26-2014 01:00 AM
