Ariens 921046 Deluxe ST28LE Vibration - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-13-2019, 08:26 AM Thread Starter
I have the above snowblower with less than 10 hours of operation.
When I took it out this morning, I noticed that there is an excessive vibration when the speed selector lever is in a forward gear and the traction drive clutch lever is held down. This does not happen when it is sitting still or I have it in a reverse speed and the traction drive clutch lever is held down.
Does anyone know what's wrong?
Thanks!
65Nova is offline
post #2 of 5 Old 02-13-2019, 01:36 PM Thread Starter
edited original post for clarification
65Nova is offline
post #3 of 5 Old 02-13-2019, 02:20 PM
Thanks (Received): 44
Likes (Received): 113
Does the unit move like it is supposed to when you engage the drive clutch handle.
You could do a quick drive belt check and make sure that proper tension is on the belt when handle is engaged.
Check your drive clutch cable for excessive slack.
Look behind left tire and forward of the axle you should see a tab that moves when you engage the handle, the book says to adjust to where that tab touches the forward part of the slot when the handle is not engaged, however I set mine to where it is approx. 1/16 + away from tab. It just works better, if the cable is to slack the friction disc may not be engaging the drive hub with enough pressure causing skipping or jumping , and as well premature wear on the friction disc
Lottstodo is offline
post #4 of 5 Old 02-13-2019, 08:11 PM Thread Starter
Thanks for the help.
I pulled the belt cover.
When I engage the clutch, the pulley/wheel (drive hub?) that moves towards the friction wheel is throwing sparks.
Is something loose or broken?
65Nova is offline
post #5 of 5 Old 02-15-2019, 05:06 PM
Cutter's Avatar
Likes (Given): 117
Likes (Received): 121
Do as Lottsdodo has already mentioned, and in further inspection, use a cable tie to engage your auger leaver with the engine running and the belt cover off. You'll be able to see if the gearbox is vibrating, how the belts are running, pulleys are spinning ( had an improperly seated pulley on the bucket causing me alot of vibration) , so as to eliminate any of these issues.
Then check your transmission with the lower plate removes to see if your friction disk engages properly. Inspect the friction disk......check You Tube and watch several videos.
Life is short, so if you don't have the strength to laugh at yourself,
call me.....I'll laugh at you!
2014 Ariens Deluxe 28 with 291 CC Engine
2011 John Deere JS36 Self Propelled Mower
Too many Craftsman Mechanic/Yard tools to mention
Cutter is offline
Similar Threads
My Pre-Snow reaction and review of my new Ariens Deluxe 28 SHO! TSR7 Ariens Snowblowers 8 11-17-2016 08:43 PM
My first experience with my new 24" Ariens Deluxe Two-Stage brvid General Snowblower Discussion 9 01-24-2015 06:01 PM
Help Me Decide....New Ariens Deluxe 28 or repair Tommymc General Snowblower Discussion 24 12-20-2014 03:02 PM
Ariens 24 SHO or Platinum or Deluxe bniez General Snowblower Discussion 25 12-10-2014 05:26 PM
Ariens Deluxe Platinum 30 Review fronos4 Snowblower Reviews 5 12-03-2011 03:32 PM
