Troubles removing carb - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-13-2019, 12:57 PM Thread Starter
Thanks (Received): 7
Likes (Received): 11
Hi guys..
I want to replace the carb on my ariens 1028 dle pro. I got the left torx screw out but the right is really impossible and I'm stripping the inside. Do you guys have another suggestion?
Orginialy I wanted to just remove the bowl. But the black case is preventing the bowl from falling. Really annoying
1 suggestion was to dremel a line across and use a standard driver but I dont have a dremel.
Also in order to remove the black cassing would require me to remove the gas tank.
ID:	153439   Click image for larger version
Xilbus is online now
post #2 of 8 Old 02-13-2019, 01:00 PM
Jackmels's Avatar
Thanks (Received): 191
Likes (Given): 448
Likes (Received): 791
Get a pair of Vicegrips on it to break it free.
Jackmels is online now
post #3 of 8 Old 02-13-2019, 01:13 PM Thread Starter
Oh good idea. I'll try that with some wd40.
post #4 of 8 Old 02-13-2019, 01:16 PM
Bondo 287's Avatar
Likes (Given): 226
Likes (Received): 24
"Seconding" the Vice-grips suggestion. That's a nice healthy cap to grab and it won't even put up much of a fight. Skip the oil. You'll see.
I always suspected the reason manufacturers put Phillips bolts on these little engine intakes is to keep users from stripping the threads or cracking the carb housing.
ARIENS ST270
Bondo 287 is offline
post #5 of 8 Old 02-13-2019, 04:06 PM Thread Starter
Thanks guys, the vice grip did the job. Cleaned all the parts and now it's back up and running
post #6 of 8 Old 02-13-2019, 04:15 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 235
One thing about Phillips drivers I've learned the hard way in recent years is it pays to have a good set of different sized Phillips heads to get that "exact fit" for any particular screw.
There are some you can get away with a non-matching driver, ones not tightened by The Incredible Hulk of the assembly line. But most times now I pull out my entire set and find the one that fits exactly into that screw head perfect (the screwdriver will not tip or tilt while sitting in the head), then give it a whirl and hope the screw itself isn't some sort of cheap soft strippable metal.
tlshawks is offline
post #7 of 8 Old 02-13-2019, 10:14 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
I have a set of diamond tip screwdrivers that I never use unless I can not get the screws loose using a regular screwdriver. They have always worked. Wonderful.
post #8 of 8 Old 02-14-2019, 01:32 AM
Thanks (Received): 25
Likes (Received): 31
Tecumseh sells 6" T30 drivers that will give you enough deflection to remove them. Worst case scenario you can remove the blower housing and take the manifold off (its bolted to the back of the block).
SnoThro is offline
Similar Threads
video removing the carb from my craftsmans 10hp tecumseh 30+ yr old snowblower vinnycom Snowblower Repairs and Maintenance Forum 6 06-14-2018 04:00 PM
Some info about buying an Ultrasonic Cleaner JLawrence08648 Snowblower Repairs and Maintenance Forum 42 03-06-2018 12:30 PM
Steps to rebuilding a carb from poor to thorough JLawrence08648 Snowblower Repairs and Maintenance Forum 6 02-18-2017 11:00 AM
Removing Carb on Toro 1128 Westboh Snowblower Repairs and Maintenance Forum 8 01-30-2016 06:29 AM
looky here Tecumseh carb problem mystery solved greatwhitebuffalo Snowblower Repairs and Maintenance Forum 21 11-29-2014 10:24 PM
