Shear Bolt Change? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-14-2019, 12:31 PM Thread Starter
Thanks (Given): 15
Likes (Received): 15
Shear Bolt Change?
My local Home Depot had previously had Ariens OEM Shear Bolt packages, but were all sold out. I ordered from Home Depot to be delivered to the store (closer than the Ariens Dealer) and didn't want to roll the dice with Amazon fakes.
It appears my order was shipped directly from Ariens to Home Depot for me (my name is on the invoice), with the right part numbers.
However, the bolts have always been black color with the brass colored nuts. The ones I received are all silver colored.
Does anyone know if Ariens made a change to the part or changed suppliers? They were in a sealed box direct from Ariens, so I believe these are the genuine part, just different than I am used to.
AMF/Husky - Gone
Ariens 24 Platinum EFI
z28lt1 is offline
post #2 of 5 Old 02-14-2019, 12:36 PM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
They are the same, just a different coating and color
russ01915 is offline
Thanks z28lt1 thanked for this post
post #3 of 5 Old 02-14-2019, 02:14 PM
oneacer's Avatar
Thanks (Received): 129
Likes (Received): 454
Those are what you need, as long as the diameter and length are correct
oneacer is online now
post #4 of 5 Old 02-14-2019, 02:31 PM
Likes (Received): 40
Be cautious as the diameter difference may be minuscule.
I have a black one pounded into a 924039 and I realized it was wrong and have been unable to remove.
Red
bigredmf is offline
post #5 of 5 Old 02-15-2019, 06:54 PM
Likes (Received): 37
For what it's worth, my new 2018-2019 Ariens Pro32 came with two bright, shiny, silver shear pins and nuts in that little plastic carrier mounted on the machine. But at the same time I purchased several bags of replacement shear pins, also from Ariens, and those were black. Same dealer, same day of delivery, etc. My bet is Ariens has more than one qualified vendor for these parts, that they're all considered functionally interchangable, and you get whatever was most recently delivered to their Receiving dock.
IDEngineer is online now
Similar Threads
Replacement shear bolt grade Levaughn Murray Snowblowers 14 04-10-2018 05:59 PM
Shear pin/ shear bolt theory...? d3500ram General Snowblower Discussion 22 10-11-2017 09:10 AM
Shear Bolt Problem DrillerDave Craftsman Snowblowers 15 02-16-2017 07:10 PM
Honda HS622 Snowblower shear bolt alignment problem KevinK Snowblower Repairs and Maintenance Forum 2 02-15-2017 07:11 PM
Shear bolt '89 521 Tambourineman Toro Snowblowers 3 02-07-2015 10:23 PM
