28 inch Deluxe In Line Fuel Filter - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-15-2019, 02:16 PM Thread Starter
I have had nothing but problems with my 28 inch Deluxe. Purchased in 2014 after a BIG snow year. Then we had a few years of literally no snow, so I didn't use it much but always ran sea foam through at the end of the season and drained the gas tank. Midway through year 2, I had to have the carbs cleaned because the gas tank had black particles in it. Come to find out that the internal tank coating was flaking off. Same thing happened again the next year. So I replaced the tank thinking maybe I had a defect, BUT the same thing happened again with the new tank. This time instead of paying someone to clean the carbs, I replaced the carb for 30 bucks. When I did I added an in line fuel filter. Purrs like a kitten now when idling, BUT when you get into some deeper snow you can tell it can't draw the same fuel flow as it could without the filter. It gets bogged down and loses power. I am wondering if there is any sort of adjustment i can make to the carb so that when the carb wants more fuel, it can pull it easier. Can't believe I am dealing with this from an Ariens snowblower. Any help is appreciated.
mikeklaphake is offline
post #2 of 14 Old 02-15-2019, 03:52 PM
Thanks (Given): 129
Likes (Given): 388
Likes (Received): 693
Are you certain the struggling under power is due to the fuel filter restriction?
What filter did you install? The paper element ones are too restrictive for gravity fed carbs like these. Briggs makes a 150 micron red filter, suitable for gravity fed. Their 75 micron (tighter filtering) white filter is too restrictive, that's for use on engines with fuel pumps.
There's no tweak for extra fuel flow to the carb, that I can think of. With a proper filter, not clogged with gunk, the filter should be "transparent", and change nothing.
If you pull the fuel line off the carb, and open the shutoff (if equipped), do you get a good stream of gas coming out?
Thanks mikeklaphake thanked for this post
Likes Bondo 287, mikeklaphake liked this post
post #3 of 14 Old 02-15-2019, 04:23 PM
Thanks (Received): 44
Likes (Received): 113
This is why I wished that someone would make a sediment type plastic filter like the old tractors had ( glass bowl style) for small engines it would trap and filter plus you would be able to see moisture.
Wouldnt have to be big. all the old gravity feed systems had them. Even the 1948 David Bradly had it. ( still works)
Lottstodo is offline
post #4 of 14 Old 02-15-2019, 05:14 PM Thread Starter
I ordered the replacement carb off of Amazon. Here's the link. I used the filter shown in the photos.
post #5 of 14 Old 02-15-2019, 05:18 PM Thread Starter
So this is probably what I should try?
post #6 of 14 Old 02-15-2019, 05:23 PM
mats's Avatar
Likes (Received): 14
I haven't tried it myself but in theory two parallell filters should increase the flow
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
mats is offline
post #7 of 14 Old 02-15-2019, 05:55 PM
Thanks (Received): 25
Likes (Received): 31
Or LCT could stop making junk engines. The OPs problem is a manufacturing flaw. Saw it a lot. It should go away after a season or two but still ridiculous to spend a grand or more and have poorly manufactured fuel tanks. I still don't understand why they went back to a (crappy) metal to be honest. Tecumseh and Briggs used plastics tanks for decades and rarely had any issues.
Another disaster is the LCT petcocks. What a piece of junk those things are.
By the way the Honda GX engines do have the little sediment bowls as part of the petcocks. So did the Subaru Robins, Mitsubishi's, and Yamahas. Briggs still sells the petcocks with the big glass bowl like you remember too but the assembly is too large for a Snow Blower.
SnoThro is offline
post #8 of 14 Old 02-15-2019, 06:09 PM
1132le's Avatar
Thanks (Given): 31
Thanks (Received): 95
Likes (Given): 67
Likes (Received): 216
You have 7.8 hp engine on a 28 bucket of course it struggles in deep snow and wet snow
it's fairly known that its under powered
1132le is online now
post #9 of 14 Old 02-15-2019, 06:14 PM
Yea have seen many, the Ecoat on the steel inside of the tank is releasing due to stamping and pressing. I do use a clean stick magnet on the inside of the tank on real bad ones , and have gotten alot of material out not all but a lot.
I did see an article about the future of plastics and they are still having problems with aligning to new green rules plus meeting safeguards to be tolerable to new fuels and additives.
One part said the return of metal tanks will probably be used more as plastics under go more scrutiny.
post #10 of 14 Old 02-15-2019, 06:51 PM
Thanks (Given): 129
Likes (Given): 388
https://www.amazon.com/dp/B07HP2F63M..._MSYzCbFPDJ1PD
It's interesting to me that the carb included a paper fuel filter. From what I've read, those filters are too tight for gravity-fed engines (like this) which don't use fuel pumps.
https://www.amazon.com/dp/B00004RB1A..._0VYzCbHK3JKCQ
Sorry for not linking earlier (I was on my phone). Yes, that's what I use.
If you want to test your current filter, pull the line off the carb, and see how quickly the fuel comes out. It should be a decent stream. A slow trickle is probably not enough. This isn't some 300hp V8, it doesn't need to be a fire hose. But it should come out as a steady stream.
And if there *is* gunk in your fuel tank, bear in mind that even with a proper-mesh (decent-flowing) fuel filter, you may still need to replace it periodically, or test the flow from time to time, at least if you have problems. You could keep a spare filter on the shelf, for instance. The middle of a blizzard isn't the time to find out that something clogged your filter.
Likes mikeklaphake liked this post
Similar Threads
Ariens 28 deluxe fuel shut off dial broke off Gschimma Snowblower Repairs and Maintenance Forum 7 11-23-2018 05:43 PM
Do any of you install a FUEL filter? Biketrax General Snowblower Discussion 17 01-07-2018 12:37 PM
Fuel System Maintenance/Do It Or Fix It mrfixit General Snowblower Discussion 4 01-31-2017 11:09 PM
Adding a Fuel Filter Opinions nelsontj General Snowblower Discussion 1 11-15-2012 06:05 PM
Ariens 522EC Snow Thrower - Repair Manual Available? (Change Fuel Filter) Don1947 Snowblower Repairs and Maintenance Forum 3 12-13-2010 10:37 AM
