Auger bearings and ect for 1971 Ariens 24" - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-16-2019, 08:41 PM Thread Starter
Likes (Received): 22
Decided to finally tackle the 1971 Ariens 24" and get it up and running.
I was originally going to get the original engine running but it just turned out to be problem after problem. So the next step was to put a big V-twin on it. Turned out that this was too much work. There was a local sale at my Horror Freight so I broke down and bought myself a Predator 212. Spent most of the day converting the machine over to accept the 212 which was pretty easy other than a few minor modifications, but after a test run, I noticed that the auger bearings sound pretty crunchy and was wondering if anyone knows where I can get replacements for both end bearings as well as the main impeller bearing. I would like to get this machine in perfect running condition.
FlamingSpaghetti is offline
post #2 of 9 Old 02-16-2019, 08:52 PM
Thanks (Given): 21
Likes (Received): 17
Jacks small engines has these parts. You will need the model and serial number. The auger uses bronze bushings, not bearings, if it is a 10000 series, which was made in 1971.
Landngroove is offline
post #3 of 9 Old 02-16-2019, 09:18 PM Thread Starter
I believe you're right with it being a 10000 series, sadly I do not have the model or the serial number that I can tell. The sticker which appears to have contained both of them has been wiped clean. It's a pretty common model, 24" 7HP Tecumseh, the auger bearing/bushing flanges are triangular shaped with 3 bolts, big heavy duty worm gear box.
post #4 of 9 Old 02-16-2019, 09:30 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 231
Look for the frame model and serial stamped next to the left side handlebar mount on top along the rear side. It would be where the frame sticker normally would be.
That won't tell you the bucket info...but chances are the bucket is original and matched at the factory with the frame.
tlshawks is online now
post #5 of 9 Old 02-16-2019, 10:55 PM
Thanks (Given): 40
Likes (Given): 45
Likes (Received): 191
FlamingSpaghetti....
Where are you located ?? If your near the Hudson NH border I have those parts on hand, could meet up sometime tomorrow if your close.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #6 of 9 Old 02-17-2019, 02:24 AM Thread Starter
I'm in south-eastern most NY, but maybe you wouldn't object to shipping? I can provide a prepaid label for FedEx.
post #7 of 9 Old 02-17-2019, 02:43 AM
Thanks (Given): 40
Likes (Given): 45
FlamingSpaghetti... I checked and do have some parts to fit your old ariens.
Here are your bearing measurements 3/4 ID x 1 3/4 OD x 1/2 W ( Thick )
And 1" ID bushings
~~ And Lastly ~~
post #8 of 9 Old 02-17-2019, 03:00 AM
Thanks (Given): 40
Likes (Given): 45
I order almost all my parts here, always have been treated well.
Ariens Snowblower Parts | Ariens Snow Thrower Parts | PSEP.biz
Bushings.... ROT8446 ROTARY AFTERMARKET $2.55 each
Impeller bearing.... ROT487 ROTARY AFTERMARKET $12.50
You should look around the site and get any extra/spare parts you might need. The friction wheel, belts, shop pack of shear pins ... ECT.....
Friction wheel.... P7-04211 $8.95
Shop pack shear pins.... SP195 $4.90
~~ And Lastly ~~
post #9 of 9 Old 02-17-2019, 01:38 PM Thread Starter
Awesome, thank you for this! The shear pins will definitely be useful, not just for this machine but my other one too.
As for the friction wheel, mine looks brand new. I was inside the transmission last night after doing an engine swap to make sure everything is functional and make a few adjustments.
