Ariens h60 75003 b - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-18-2019, 08:21 PM Thread Starter
Unhappy Ariens h60 75003 b
I just acruired a h60 7003 b model snow blower. I saw that it is set up for a electric start. I am having a difficult time locating a starter. I can find the h60 75003 model, but not the b series. can anyone help?
kenc18901 is offline
post #2 of 8 Old 02-18-2019, 11:07 PM
Thanks (Given): 554
Thanks (Received): 731
Likes (Given): 4148
Likes (Received): 1597
to SBF kenc18901
I could be wrong so don't run with this answer just yet but any starter for a Tecumseh H60 should work. The one that popped up often was a #33328
Following from HCBPH
FYI - I've had a few TEC engines with electric starters or bought some to put on existing units (planning to sell at the time). The 3 major differences I've noted are 1) the starter button 2) electric cable length 3) the bottom mounting holes
1) The older units have exposed electrical connectors in some type of phenolic plastic case. Newer ones it's pure plastic and there's a shield than you have to have a proper sized electric cord to fit into
2) The length of the elec cord between the button and starter motor varies in length. Some I had to make up a mounting plate for them to fit the engine.
3) On the older ones, all 4 mounting holes are just that - holes. On the newer ones, two of the holes are slotted and you use shoulder bolts for mounting. You can screw in those 2 bolts and tighten them up, slip the starter onto them then insert the other 2 bolts.
That's the differences I know of.
Thanks kenc18901 thanked for this post
Likes kenc18901 liked this post
post #3 of 8 Old 02-19-2019, 08:33 AM
Thanks (Given): 67
Thanks (Received): 382
Likes (Given): 173
Likes (Received): 877
I agree, the "b" is likely irrelevant, and any starter that will fit any H60 should work..
but! not all engines are equipped to take a starter..the flywheel might not have gear teeth for a starter..
need to look at that first.
just FYI, H60 is the model of the engine only, not the snowblower!
but since you are looking for an engine part, you dont need the model number of the snowblower anyway..
Likes kenc18901, Kiss4aFrog liked this post
post #4 of 8 Old 02-19-2019, 02:53 PM Thread Starter
Thank you for your help. I can see that there are four holes for mounting and the flywheel is exposed where I believe a starter would go. I can see that the flywheel has gears that resemble what a car would have for a starter. Thank you again
post #5 of 8 Old 02-19-2019, 03:26 PM
Thanks (Given): 554
Likes (Given): 4148
Also don't get fooled by H60, HS60 or HSK60 as they are all the same as far as the starter goes.
For a "snow" engine they may have an added primer and no air filter but the rest of the engine is the same as a lawnmower or tiller as far as a starter would be concerned.
Out of curiosity, what Ariens is it you have this H60 sitting on ??
post #6 of 8 Old 02-20-2019, 01:56 PM Thread Starter
I am not really sure of the Model. The only model number that I have is H60 75003 B. I have attached some pictures.
ID:	153809   Click image for larger version
ID:	153811   Click image for larger version
ID:	153813   Click image for larger version
ID:	153815   Click image for larger version
post #7 of 8 Old 02-20-2019, 02:05 PM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 232
That's your engine. H60's do appear to require Tec# 33328's. As long as there's a ring gear it should work - the image you linked...the opening is too dark to see the teeth.
Considering the opening on the engine flywheel shroud has the plate removed, chances are an electric starter WAS there but was removed.
tlshawks is offline
post #8 of 8 Old 02-20-2019, 02:23 PM Thread Starter
Here are some better pics. Thank you again for all your help.
ID:	153819   Click image for larger version
ID:	153821   Click image for larger version
ID:	153823   Click image for larger version
Similar Threads
I reached out to Ariens with some Feedback for Auto-Turn Elt31987 Ariens Snowblowers 17 02-03-2016 04:59 PM
Ariens vs Troybilt Chad General Snowblower Discussion 11 01-31-2016 09:29 PM
my first use of 2014 ariens deluxe 28 (921036) throttlejunkie450 Snowblower Reviews 26 11-01-2015 08:22 AM
Ariens Service Bulletin and no name belts? Stevedots Ariens Snowblowers 2 02-15-2013 07:30 PM
My Ariens Pro 32 vs my old Husky (AYP) 16530E JRHAWK9 General Snowblower Discussion 4 02-09-2013 08:19 PM
