Carburetor for 922003 - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-19-2019, 05:39 PM Thread Starter
I'm having a hard time locating a new carburetor for my old 5hp Ariens model 922003. I cannot find the engine model # on the unit, but I believe its original and according to the owners manual its a Tecumseh HSSK-50 67008. I'm looking for a part number for a new carb or any information that can assist me in finding a replacement part.
Strangebrew is offline
post #2 of 15 Old 02-19-2019, 06:00 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 182
use this site to help u narrow down ur search , also has great info on carbs.
any 5hp carb for tecumseh will suffice, just match up to what yours looks like
use Tecumseh HSSK-50 as your seach info on buying one
Tecumseh Carburetor Manufacturing Numbers
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #3 of 15 Old 02-19-2019, 06:03 PM
Thanks (Given): 26
Thanks (Received): 80
Likes (Given): 80
Likes (Received): 230
Why replace? Rebuild what you have and *KNOW* you have the right one!
tadawson is online now
post #4 of 15 Old 02-19-2019, 10:53 PM
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
Try 632107 or 640084b
post #5 of 15 Old 02-20-2019, 10:05 AM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 235
FYI 922003 is a 20" bucket model #. If you have a 5HP tractor, that I believe should be a 922008 (1974) or 922014 (1975). The tractor data sticker should be near the left lower handebar and if the sticker is gone, the data should be stamped there also.
I'd search for a replacement via the engine data. Make sure it looks exactly like the carb you got already, is an adjustable carb etc.
tlshawks is offline
post #6 of 15 Old 02-20-2019, 12:20 PM Thread Starter
Thanks for all your feedback - very much appreciated!
My father in-law gave this snowblower to me so I would really like to keep it, however I am not mechanically inclined, so I am relying on a small engine tech to do the repairs. He informs it can't be rebuilt, and he's unable to locate the part # so I am doing the legwork to try and figure this out. Kind of like finding a needle in a haystack so far.
I confirmed bucket # is 922003 and tractor # is 922008 (serial #011608) - both stickers still on the unit. However, I cannot find the engine data on the unit.
post #7 of 15 Old 02-20-2019, 12:40 PM
Likes (Received): 279
The link that Vinny has will lead you to the carb your looking for - you need to get the numbers off the carb itself...... then match it up. they can be rebuilt if it's not to corroded or gunked up.... but it's easier and cheaper to just swap it out with one of the China made replacements on Ebay. I have swapped out dozens of them. Just pay attention to the choke configuration - most times you will have to swap the choke levers from the old one to the new one..... otherwise order a rebuild kit and do the best you can cleaning it. I think you got a lazy tech from the sound of it..... if they stock kits for most carbs he could stare and compare with the stuff he has. There aren't that many different configurations....
Here's my guess - https://www.ebay.com/itm/Carburetor-...UAAOSwETJaKQqw
OR https://www.ebay.com/itm/new-Tecumse...ss!52405!US!-1
post #8 of 15 Old 02-20-2019, 01:10 PM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 121
640084B is my bet!!!!!
Per Oregon website this cross references to these Tecumseh carbs.:
Tecumseh 1099, 1432, 632334, 632334A, 640084B
And fits these Tecumseh Engines:
Tecumseh 5145 Mfg. No., 5285 Mfg. No., 640084A-TEC, 640084B-TEC, HM80-155001J, HM80-155001K, HM80-155001L, HM80-155001M, HM80-155013J, HM80-155015J, HM80-155022J, HM80-155022L, HM80-155022M, HM80-155128J, HM80-155132J, HM80-155169J, HM80-155186J, HM80-155198J, HM80-155206J, HM80-155206K, HM80-155207J, HM80-155209J, HM80-155209K, HM80-155209L, HM80-155209M, HM80-155209N, HM80-155209P, HM80-155212J, HM80-155212M, HM80-155233J, HM80-155237J, HM80-155241J, HM80-155241K, HM80-155242J, HM80-155245J, HM80-155246J, HM80-155247J, HM80-155248J, HM80-155249J, HM80-155254J, HM80-155255J, HM80-155271J, HM80-155271K, HM80-155273J, HM80-155273K, HM80-155273L, HM80-155273M, HM80-155274J, HM80-155275J, HM80-155276J, HM80-155276K, HM80-155277J, HM80-155277K, HM80-155277L, HM80-155278J, HM80-155279J, HM80-155279K, HM80-155280J, HM80-155280K, HM80-155281J, HM80-155282J, HM80-155282K, HM80-155282L, HM80-155282M, HM80-155283J, HM80-155283K, HM80-155283L, HM80-155284J, HM80-155291K, HM80-155291L, HM80-155291M, HM80-155291N, HM80-155291P, HM80-155292K, HM80-155292L, HM80-155293K, HM80-155293L, HM80-155294K, HM80-155296K, HM80-155297K, HM80-155298K, HM80-155298L, HM80-155298M, HM80-155298N, HM80-155298P, HM80-155307L, HM80-155308L, HM80-155308M, HM80-155308N, HM80-155308P, HM80-155309L, HM80-155309M, HM80-155309N, HM80-155309P, HM80-155310L, HM80-155310M, HM80-155310N, HM80-155310P, HM80-155311L, HM80-155311M, HM80-155311N, HM80-155311P, HM80-155312L, HM80-155312M, HSSK50-67261U, HSSK50-67385T, HSSK50-67385U, HSSK50-67386T, HSSK50-67388S, HSSK50-67389S, HSSK50-67390S, HSSK50-67391S, HSSK50-67392S, HSSK50-67393S, HSSK50-67393T, HSSK50-67393U, HSSK50-67394S, HSSK50-67394T, HSSK50-67394U, HSSK50-67395S, HSSK50-67395T, HSSK50-67396S, HSSK50-67397S, HSSK50-67398S, HSSK50-67399S, HSSK50-67400S, HSSK50-67401S, HSSK50-67402T, HSSK50-67402U, HSSK50-67403S, HSSK50-67403T, HSSK50-67403U, HSSK50-67404S, HSSK50-67404T, HSSK50-67404U, HSSK50-67405S, HSSK50-67406S, HSSK50-67407S, HSSK50-67408S, HSSK50-67409S, HSSK50-67409T, HSSK50-67410S, HSSK50-67410T, HSSK50-67410U, HSSK50-67411S, HSSK50-67411T, HSSK50-67415S, HSSK50-67416T, HSSK50-67416U, HSSK50-67417T, HSSK50-67417U, HSSK50-67417V, HSSK50-67418U, HSSK50-67419U, HSSK50-67420U, HSSK50-67421U, HSSK50-67422U, HSSK55-67501A, HSSK55-67501B, HSSK55-67501C, HSSK55-67502B, HSSK55-67502C, HSSK55-67503B, HSSK55-67504C, HSSK55-67505C, HSSK55-67506C, HSSK55-67507C, LH195SA-67385V, LH195SA-67386V, LH195SA-67387V, LH195SA-67394V, LH195SA-67403V, LH195SA-67405V, LH195SA-67416V, LH195SA-67417V, LH195SA-67418V, LH195SA-67419V, LH195SA-67420V, LH195SA-67422V, LH195SA-67424V, LH195SA-67427V, LH195SA-67428V, LH195SA-67429V, LH195SA-67430V, LH195SA-67431V, LH195SA-67432V, LH195SA-67433V, LH195SA-67434V, LH195SA-67435V, LH195SA-67437V, LH195SA-67438V, LH195SA-67440V, LH195SP-67427V, LH195SP-67501D, LH195SP-67504D, LH195SP-67508D, LH195SP-67510D, LH195SP-67511D, LH195SP-67512D, LH195SP-67513D, LH195SP-67514D, LH195SP-67517D, LH195SP-67518D, LH195SP-67519D, LH195SP-67520D, LH195SP-67521D, LH195SP-67522D, LH195SP-67523D, LH195SP-67524D, LH195SP-67525D, LH195SP-67526D, LH195SP-67527D, LH195SP-67528D, TEC-640084A, TEC-640084B
SimplicitySolid22 is offline
post #9 of 15 Old 02-20-2019, 02:13 PM
Thanks (Given): 26
Likes (Given): 80
Looking at the Arien's parts manual for that vintage, the only 5HP engine used was the HS50-67008. Doing a search, I find that the service carb listed for that engine is a 631953 (listed by Jack's small engines as well as others).
All the docs are there, you just need to find and use them . . .
post #10 of 15 Old 02-20-2019, 02:28 PM Thread Starter
The number on my carb is 433 3H29. When I look this up via the link that Vinny provided, I see that manufacture #433 corresponds to carb service # 632795A.
Thoughts?
