1978/79 Ariens 924026 - Rear Axle to Differential Question - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-22-2019, 01:06 PM Thread Starter
I just replaced both of the bronze axle bushings on my 1978/79 Ariens 924026 snowblower and everything came apart and went back together easy enough but the one odd thing I noticed was that the differential gear is a bit sloppy on the axle. All the teeth on both sides of the axle and on the differential look ok (nothing broken or excessively worn) and it seemed pretty solid when I took it apart. I did totally clean everything and I am wondering if it normal to have some looseness to the axles to differential fit? The blower always works great and has plenty of drive to the wheels. The cost of a new axle and/or differential is really costly so I'm hoping this is ok.
Thanks,
Eric
hatrick is offline
post #2 of 3 Old 02-22-2019, 05:02 PM
Jackmels's Avatar
Thanks (Received): 191
Likes (Given): 448
Likes (Received): 789
Get the Grease Gun, and make sure the Differential Side is Greased well. The Zerk is on the Axle Flange.
Jackmels is offline
post #3 of 3 Old 02-22-2019, 09:02 PM Thread Starter
Already greased the zerk and where the two ends of the axles go into the differential.
hatrick is offline
Similar Threads
Ariens 10,000 oil leak rear of differential to impeller Landngroove Snowblower Repairs and Maintenance Forum 5 07-11-2018 08:58 PM
Used Ariens Question GBP4EVER General Snowblower Discussion 25 01-31-2016 10:40 PM
Ariens st824 gearcase oil seal question jenkinsm2 Ariens Snowblowers 5 04-25-2015 02:17 PM
hello everyone new guy w/ ariens 1128 question bill64 Ariens Snowblowers 4 02-14-2013 04:34 PM
Ariens ST724 (924075) Axle Play, Pics/Video, Need Assistance! highvoltz Snowblower Repairs and Maintenance Forum 6 10-25-2011 07:29 PM
