2.7-3hp Carburetor - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 02-23-2019, 02:39 PM Thread Starter
2.7-3hp Carburetor
I have an old little Ariens 932001 with a 2.7hp engine. The original carb was a diaphragm if I recall correctly. Well at some point I had replaced it with a standard carb with a float bowl. The issue I had was that it didn't have the primer bulb connection so cold starts were not great.
I found a solution last week on Amazon, it's labeled as a 3hp 2-cycle engine carb. I took a chance and ordered one. The throttle plate connection is on the wrong side of the shaft but there was enough meat to drill a hole in the correct position, or at least close enough. It also has a bit of metal that goes up and interferes with the linkage, that snaps off easily.
I drilled the hole, snapped off the excess metal, installed it and it works great. It starts and runs better than before. Here's the Amazon link: https://smile.amazon.com/gp/product/B07GH139F9
I hope this helps someone else with one of these little blowers.
stanz is offline
Similar Threads
storm 2410 Carburetor access issue gamechanger Troy-Bilt Snowblowers 16 01-20-2019 12:52 PM
Having Trouble Removing Carburetor from Snowblower Jack28 Snowblower Repairs and Maintenance Forum 28 08-21-2017 02:36 PM
Help Finding Part (Carburetor) for Husqvarna 10530SBE Ron_C Husqvarna Snowblowers 7 10-17-2016 09:55 AM
Carburetor model number Levaughn MTD Snowblowers 10 12-16-2015 12:33 AM
HS520 Carburetor Adjustment tmort Honda Snowblowers 5 10-27-2013 06:02 PM
