924 Clutch Handle Conversion - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-24-2019, 04:39 PM Thread Starter
SHVLHEAD's Avatar
Has anyone converted a mid 70’s 924 series right hand ‘pull up’ clutch safety handle to a ‘push down’ handle set-up...similar to the 80’s handles configuration? Just curious if anyone has tried and how successful they were. After 2+ hours of SB today I can see why Ariens and other manufacturers went to the push down approach. I run a 924024 832...and after doing my drive and a few neighbors my right hand cramps up something awful.
Thanks,
Stone
SHVLHEAD is offline
post #2 of 8 Old 02-24-2019, 05:25 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 28
Likes (Received): 40
Yeah I bought John Deer Push down handle for my signature machine. I routed a newer cable from a different machine, and made a hole in the pull arm from the other side of the machine so it would pull when I pushed the handle down. I also had to make a bracket on the top end to support the new handle. I used the existing spring to to pull the idle pulley in to tighten the belt, and a much lighter spring to keep the idle pulley off the belt when it's supposed to be slack. So I went from a suicide clutch to a dead man clutch, ether way I am dead. Sorry I don't have pictures.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #3 of 8 Old 02-24-2019, 06:06 PM
Thanks (Received): 204
Likes (Received): 742
How about swapping the handles from an ST 824...get rid of the twin stick all together....
cranman is offline
post #4 of 8 Old 02-25-2019, 10:56 AM
tlshawks's Avatar
Thanks (Given): 24
Thanks (Received): 41
Likes (Given): 44
Likes (Received): 235
I'm betting you'll need to have the lever, clutch rod, swivel joint, and I'm assuming there'll be a plastic mounting block too - to do it up right.
On my 22,000 series handlebars swap (922002 handlebars onto a 922008 frame), I tried using the '002 pull style right hander and it didn't work even though the handlebars and frame are darn near exactly the same. I had to swap over the '008 lever assemblies complete. The '002 bars did not have the pre-drilled block mounting holes on the left side handlebar, nor was there an "indentation" on the left where the lever mounting block screws passed through from the top.
I was able to make it work, but I had to use the mounting block holes as guides to drill new holes to mount the lever block.
I'm betting it can be done, but if you have a complete machine the way you want it to operate as a guide, it'd make knowing what needs to be done a lot easier. I know the cramping feel...my '002 does it to me also. I could probably lighten up on my friction disc adjustment to relax the tension I set it up for (for maximum disc grip to the drive plate) - my fear is I may have some slippage as a result.
That's "fine tuning" of The Badger I have scheduled for this week.
tlshawks is offline
post #5 of 8 Old 02-25-2019, 02:31 PM Thread Starter
SHVLHEAD's Avatar
Thanks for the feedback everyone. Good to see that others have accomplished this task. I think I have everything in inventory except the plastic mounting block tls...and that is the part I can probably manufacture myself. At least I have some food for thought as this will be placed on my to do list over the summer
Thanks,
Stone
SHVLHEAD is offline
post #6 of 8 Old 02-27-2019, 12:04 AM
Ian Ariens 924's Avatar
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 22
I sell lots of the 924 series, on most all of them I tape the lever up or the safety lever wiring has been disconnected altogether.
Ya,It is not correct but thats what most people do.
Ariens 924024 8 hp 32” now a 10 hp
Ariens 910008 7 hp 24”
Ian Ariens 924 is offline
post #7 of 8 Old 02-27-2019, 01:24 PM Thread Starter
SHVLHEAD's Avatar
That solution did cross my mind Ian...the taping, not the disconnect. I even thought about using my daughter's ponytail holder to hold it in the up position, just roll it off the lever when needed. This would also maintain the 'original' integrity of the machine as well, of which I am a big proponent of.
Doesnt disabling a safety feature of the machine and selling it put you at risk should something happen in the future? I remember working for a hardware store (early 80's) about the time when safety clutches came out on lawn mowers. A customer asked that the safety clutch lever be taped down so the mower wouldnt turn off and the owner of the hardware store explained we couldnt do that for liability purposes. Reading your reply reminded of that conversation...
Thanks,
Stone
SHVLHEAD is offline
post #8 of 8 Old 02-27-2019, 11:30 PM
Thanks (Given): 20
Likes (Given): 48
Stone, I show the purchaser the snowblower,explain the safety lever and its purpose,if the guy wants to keep the tape or tape it himself,it’s up to him.If the engine has been replaced most times the safety is disabled.
I am just selling a snowblower not sure I hold any liability selling a used 30 year old snowblower.
Everything worked when I sold it .
Similar Threads
New member - just picked up a 10000 series on Tuesday Mr_Ramsey Ariens Snowblowers 27 12-10-2018 06:00 PM
Need help replacing right side clutch handle for track on hss928 orangputeh Honda Snowblowers 19 07-17-2018 12:02 PM
Reversing Clutch handle? rmpitzer Ariens Snowblowers 10 12-04-2016 11:03 AM
Auger Clutch Lever Problem garytw Simplicity Snowblowers 2 10-21-2016 03:13 PM
Manual pull starter on Craftsman snowblower Grayte Snowblower Repairs and Maintenance Forum 17 01-12-2011 11:23 PM
