1970s Ariens Tear Drop - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 03-08-2019, 01:05 PM Thread Starter
Thanks (Given): 9
Hi guys,
Thought I'd start a new thread in the appropriate forum. You guys helped out a lot here: https://www.snowblowerforum.com/foru...-2-stages.html)
I ended up finding a free Ariens 8HP 24" snwoblower. It came missing a bunch of small screws and the hardware was missing. Ended up going to Stephen's Small engine in Pickering and the guy there helped out with all the small screws I was missing as well as a gasket for the carb/manifold. All in $10.
I ran into a few hiccups.
First was figuring out how it all went back together. I've attached a pic. I understand now why the original owner removed the governor arm but it's definetly not required. Just need to take your time and go in the right sequence.
Next, I got it running but it was leaking fuel. Checked the needle and seat and all that looked good.
It turned out it was a small breather hole that I didn't know existed until I saw this video. Opened this hole up and the leak was solved.
The next issue was the fuel tank included (snow king) didn't match up with the original bracket. I ended up using a my cutting wheel and was able to salvage the old bracket. I had to cut a piece around the top to make room for the gas cap. I also had to cut off a bit of the bottom bracket so it would fit in the ridge provided.
Next steps:
1) I need to find some skid shoes. I'm debating on whether to buy these new or DIY them somehow. Any input would be appreciated. I've got an old bed frame that I think I could probable jig something up. Or I've seen the diy poly solution. Or should I just pony up the cash and get some prefabbed ones.
2) I want to do an impeller kit on these. I just need to find some material.
Anything else I sholuld look to do? I'm not sure if I'm going to keep this or not. I do really like my toro single stage Rtek. I'm hoping I can test this guy out at somepoint.
Attached some pics. Thanks for all help guys!
ID:	154705   Click image for larger version
ID:	154707   Click image for larger version
ID:	154709   Click image for larger version
ID:	154711   Click image for larger version
Rutom is offline
post #2 of 4 Old 03-08-2019, 02:18 PM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 81
Likes (Given): 233
Likes (Received): 183
They use skid shoes with standard 3" spacing and you can find a new pair of pre-fabbed ones for ~$15 including shipping all day long on ebay:
https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
db130 is online now
post #3 of 4 Old 03-10-2019, 12:28 AM Thread Starter
Thanks (Given): 9
Ended up putting on some Atlas 490-241-B010 shoes on. They definitely help make this beast more maneuverable.
Rutom is offline
post #4 of 4 Old 03-10-2019, 01:22 PM
Thanks (Given): 559
Thanks (Received): 735
Likes (Given): 4174
Likes (Received): 1605
What kind of surface are you using it on ? Those poly shoes would be good for concrete or asphalt.
Similar Threads
Bought Troy 2860 - should I have gone Ariens deluxe 28? 445gsd General Snowblower Discussion 1 12-31-2019 02:58 PM
Buying advice: 28" Cub, Ariens, Honda? mgvrmark General Snowblower Discussion 33 03-10-2019 12:53 PM
Where can I get 1960-1979 Ariens Orange Spray paint? FearlessFront Ariens Snowblowers 6 09-08-2017 09:34 PM
1970's Ariens, My first post blk05crew Ariens Snowblowers 23 01-06-2017 02:40 PM
My Ariens Pro 32 vs my old Husky (AYP) 16530E JRHAWK9 General Snowblower Discussion 4 02-09-2013 08:19 PM
