Ariens ST824 older model no spark - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 03-10-2019, 08:42 PM Thread Starter
Hello all! I’m a retired elevator tech so I figured when I told my buddy to bring his snowblower that’s been sitting out in the weather for a couple years, I would fix it. I mean how hard can it be? It’s the 8 hp model with a tecumseh engine.
The fuel lines were rotten so I replaced them. I also sprayed carb clean through the carburetor. I bought a new one but haven’t installed it yet. I checked for spark and there was none, so I replaced the spark plug. Still no spark. I tested it by taking the plug out and touching it to frame ground. Nothing. So I bought a spark plug tester with a light in it. Nothing.
Next I took the pull start housing off, and the gear so I could get to the points and coil and condenser. I also replaced the key switch because it had no continuity when off. I checked the circuits with my ohm meter and everything was grounded, so I took the points, condenser and coil assembly off and checked the coil. It only had .7 ohms through it so I thought that was a problem. The new one I bought has the same ohms.
I installed the new points, condenser, and coil, and tested for spark again. No spark. I tested the points circuit that removes the circuit from ground when it opens the contact, but that.7 ohms across the coil seems to keep ground. So I am asking if anyone can tell me if that .7 ohms across the two coil leads is correct. I’m pretty sure I have it wired right, but I would appreciate some direction.
Much Thanks!
Fred
Fredrick Hela is offline
Similar Threads
Ariens ST824 '79 or '80? greyno3 Ariens Snowblowers 10 01-23-2019 02:25 PM
Old Ariens st824 model: 924050 Julien Morrissette Snowblower Repairs and Maintenance Forum 56 12-17-2017 12:31 PM
Ariens st824 J_G_M Ariens Snowblowers 5 06-01-2017 04:07 PM
Ariens ST824 run problem Juliemac Ariens Snowblowers 1 12-27-2016 01:53 PM
Ariens ST24DLE when was this model first marketed? Quickrick Ariens Snowblowers 2 05-03-2011 02:36 PM
