New to me 11528LE 926102 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-16-2019, 08:44 AM Thread Starter
Michele's Avatar
Likes (Received): 7
Recently acquired this machine it’s a 2005. It needs some work but cosmetically it’s nice other than being filthy when I got it.
Had to soak and thoroughly clean the carburetor to make it run. Then changed the oil and tuned it up and adjusted cables.
I plan on doing the dual belt upgrade, replacing the starter, and I’ve replaced a pinion gear and shaft that came in a kit for $68. Some dumb ass jammed a regular bolt in place of one of the shear pins but hopefully I can get that out.
We still had some piles of snow here the other day so I went at it and wow this thing is really awesome I like it better than my other snowblower. Thinking it will be worth it in the long run to get it up to speed. My other machine is a 2004 Craftsman 9HP 28” (also with a Tecumseh engine) I bought new. I’ll add pics of both but very excited to get this machine I’ve never owned an Ariens before. 😁👍
ID:	154993   Click image for larger version
Michele is offline
post #2 of 13 Old 03-16-2019, 01:39 PM
Thanks (Received): 372
Likes (Received): 1313
MAZEL TOV on That 1.
POWERSHIFT93 is online now
post #3 of 13 Old 03-17-2019, 01:10 AM
Thanks (Received): 723
Likes (Given): 4133
Likes (Received): 1583
It's kind of night and day between the two. Seeing as they are both 28's you'll notice the Ariens is substantially heavier.
Not good when trying to load/unload from a trailer but wonderful in holding up to use and abuse for many, many years.
post #4 of 13 Old 03-17-2019, 02:34 AM
Thanks (Received): 67
Likes (Given): 63
Likes (Received): 221
nice machine. both are good machines but i think the biggest setback on the craftsman like yours is the rectangle impeller output. it almost limits how much snow your machine can throw out. the round output seems to allow for maximum snow output compared to a rectangle.
yardworks 31AH6WKF515
crazzywolfie is online now
post #5 of 13 Old 03-17-2019, 11:28 AM
88-tek's Avatar
Thanks (Received): 8
Likes (Given): 38
Likes (Received): 27
Super nice Ariens you got there.
You have one of the finest snowblower brands on the planet.
When you get a chance, tip the blower on it's nose and check the friction disc and drivetrain underneath. Make sure that "dumbass" didn't do any other "hack" repair jobs.
HEY LASERLIPS, YOUR MAMA WAS A SNOWBLOWER!!!
2017 Sno-Tek
1995 Chevy K1500
1990 John Deere Hydro 175
88-tek is offline
post #6 of 13 Old 03-17-2019, 11:34 AM
db130's Avatar
Thanks (Given): 16
Thanks (Received): 78
Likes (Given): 230
Likes (Received): 181
That Craftsman snowblower should be a 29" and not a 28", no?
db130 is online now
post #7 of 13 Old 03-17-2019, 03:36 PM Thread Starter
Michele's Avatar
Likes (Received): 7
. Yup you’re correct the Craftsman is a 29”. Haha I had 28” on the brain.
Michele is offline
post #8 of 13 Old 03-17-2019, 03:53 PM Thread Starter
Michele's Avatar
Likes (Received): 7
Originally Posted by 88-tek View Post
Super nice Ariens you got there. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
When you get a chance, tip the blower on it's nose and check the friction disc and drivetrain underneath. Make sure that "dumbass" didn't do any other "hack" repair jobs. [IMG class=inlineimg]https://www.snowblowerforum.com/forum/images/smilies/laugh.gif[/IMG]
. 88tek yes I’ve been in there already because the drive wouldn’t engage so I had to replace the pinion shaft and gear + frame repair kit. Works great now.
The PO did hack up the auger and I can’t get that bolt out but it wouldn’t do much good as the augers are rusted to the axle shaft. 😥. The skids were not adjusted correctly and as a result the scraper bar is chewed down to the bolts on one side. Despite that it’s a solid machine and runs strong so I’m going to keep it and use it next winter. I’ll replace the scraper bar this Spring. Maybe I’ll come across a reasonably priced working second hand auger assembly down the road.
Michele is offline
post #9 of 13 Old 03-17-2019, 05:41 PM
88-tek's Avatar
Likes (Given): 38
Good to know everything is fine in the back.
Have you tried using a punch or extraction screws to remove the bolt?
If you can get the bolt out, There are a few techniques you could try to free the augers from the shaft. here is a link.
https://www.snowblowerforum.com/foru...ted-shaft.html
Just a suggestion to help save you some $$
2017 Sno-Tek
1995 Chevy K1500
88-tek is offline
post #10 of 13 Old 03-17-2019, 06:23 PM Thread Starter
Michele's Avatar
Likes (Received): 7
88tek I haven’t tried very hard to get the bolt out but will when our daytime temps warm up some. Thanks for taking the time to post that link 😁👍 much appreciated.
Michele is offline
Similar Threads
Used Ariens 11528LE for $900 CAD? CJB Ariens Snowblowers 14 11-04-2019 07:14 PM
11528le rpm under load nymtber Ariens Snowblowers 5 01-24-2019 04:20 AM
Replace Ariens 11528LE with Honda HS828? Brian Sargent General Snowblower Discussion 19 10-01-2017 01:33 PM
Ariens 11528LE 2006 Roy Snowblower Reviews 3 02-01-2015 06:18 PM
Ariens 11528LE - value? CO Snow Ariens Snowblowers 15 01-04-2015 03:14 PM
