Seized 250cc on 921022 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 07-21-2019, 09:42 PM Thread Starter
I have a 921022 with a seized motor (1150 ft/lbs , 250cc) my question is can I put a 1650 ft/lbs 342cc direct swap without modifying anything.? If I need to modify something some guidance would be greatly appreciated
Peterblueeyes is offline
post #2 of 5 Old 07-22-2019, 10:37 AM
Thanks (Given): 13
Thanks (Received): 124
Likes (Given): 145
Likes (Received): 286
I donít know if there are multiple mounting holes on that blower but the 254cc (what the newer ones are using) but from that size down is the smaller block and the step larger uses a larger block with different mounting bolt locations.
Dauntae is online now
Thanks eyebolt thanked for this post
Likes eyebolt liked this post
post #3 of 5 Old 07-22-2019, 11:26 AM Thread Starter
This model came with 3 motor option 1150, 1450 and the 1650 are they drop in or do I have to mod the pulleys and belts and basse ? For the 1650 motor
post #4 of 5 Old 07-22-2019, 02:43 PM
Thanks (Given): 13
Likes (Given): 145
Should line up as long as you get the same shaft size you should be able to use the same pillows, the different mounting locations are there just so they line up, Buddy also has I think the same model with the 250cc Briggs and heís loving it.
post #5 of 5 Old 07-22-2019, 03:40 PM
Jackmels's Avatar
Thanks (Received): 191
Likes (Given): 448
Likes (Received): 789
Why not Try to Free up the Seized motor? First, Fill crankcase with oil, and then Liberally Spray PB Blaster or penetrating oil in the spark plug hole. Put a Pipe wrench or large vicegrips on the crank, and slowly move it back and forth until it frees up. Then try starting it. You never know.
Jackmels is offline
