replacement Halogen for 00432600 12v20w - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 10-08-2019, 11:30 AM Thread Starter
Likes (Received): 23
I see that Philips and Sylvania have 881 lamps that look right but they list it as a 12.8v 27w. Would this work or is the additional 7w pushing it on a 921050?
thank you
trellis is offline
post #2 of 9 Old 10-08-2019, 11:52 AM
Thanks (Given): 13
Thanks (Received): 123
Likes (Given): 144
Likes (Received): 284
I would say its pushing it on the stator, will work but the stator life may not be very long.
Dauntae is online now
post #3 of 9 Old 10-08-2019, 02:03 PM
Likes (Given): 23
Likes (Received): 19
I'm hoping someone suggests an LED 881 bulb brand and specs that they have had success with. LED has to be the way to go, but a quick ebay search yields way too many choices. Wattage, lumens, color temperature, etc...
Ariens Hydro Pro 28
CTHuskyinMA is online now
post #4 of 9 Old 10-09-2019, 12:19 AM Thread Starter
“I would say it’s pushing it on the stator, will work but the stator life may not be very long.”
Would it only be a problem if the heated grips are on? With them off could it handle a 35w lamp ( I think that would be the 862 )
trellis is offline
post #5 of 9 Old 10-09-2019, 12:24 AM Thread Starter
“I'm hoping someone suggests an LED 881”
I have 3 wired together ( similar to how others have in the led thread) and I’m not entirely sure I like them. The pattern and output doesn’t appear as nice as the halogen. Maybe I just don’t have good ones?
trellis is offline
post #6 of 9 Old 10-09-2019, 12:48 AM
Thanks (Received): 69
Likes (Given): 63
Likes (Received): 222
usually the heated grips are on a different stator from the from the lights unless there are 2 wires coming out of the stator for some other reason.
yardworks 31AH6WKF515
crazzywolfie is online now
post #7 of 9 Old 10-09-2019, 10:19 AM Thread Starter
Here's the wiring diagram for the Ariens 24sho 921050, looks like it's has one feed, is that correct? thanks
trellis is offline
post #8 of 9 Old 10-09-2019, 02:42 PM
enigma-2's Avatar
Thanks (Received): 19
Likes (Received): 48
Stator is rated 60 watts, grips around 35, halogen light around 20 (from what I've read, its about 18.4 watts actually). Bypassing the halogen allows 25 watts, 27 should still be safe (with heated grips on) imo.
2014 Ariens 24" Platinum
Toro CCR 3650 GTS
enigma-2 is offline
post #9 of 9 Old 10-09-2019, 06:19 PM Thread Starter
Thanks enigma,
Would a fuse protect the stator or only the load?
trellis is offline
