Ariens 1128 Engine - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 11-15-2019, 05:51 PM Thread Starter
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
Ariens 1128 Engine
Hi,
I’m going to look at a 2002 or so Ariens 1128 model # 924334 .Sheet metal is really nice, but it does not run.
It seems to have a LH Tec 11 hp engine on it,I believe it is an overhead valve set up.
Can I get your opinions on this motor?
Are there any issues with these ?
Can I just replace the Tecumseh LH OHV with a Tecumseh 10 hp flathead if needed
I am only familiar with Tecumseh flat head 8 and 10 hp old motors.
Ariens 924024 8 hp 32” now a 10 hp
Ariens 910008 7 hp 24”
Ian Ariens 924 is offline
post #2 of 17 Old 11-15-2019, 06:45 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
I like tecumseh more also but after buying a new machine with the LCT it seems like a good engine. New parts are just as easy to get for them
e.fisher26 is online now
Thanks Ian Ariens 924 thanked for this post
post #3 of 17 Old 11-15-2019, 07:17 PM
Thanks (Given): 173
Likes (Given): 451
Likes (Received): 1029
Question
Replacement engine? When did Ariens begin using LCT engines? (FYI I understand they're not a bad engine) It probably originally came with a Tecumseh.
post #4 of 17 Old 11-15-2019, 07:19 PM
Likes (Given): 44
2012 ish. Might still be Briggs if bigger engines 12+ hp maybe
post #5 of 17 Old 11-15-2019, 07:37 PM Thread Starter
Thanks (Given): 20
Likes (Given): 48
Correction , parts supplier on net says it’s a 11 hp Tec Lh engine OHV.
Here is a picture of the engine
post #6 of 17 Old 11-15-2019, 09:09 PM
Thanks (Given): 173
Likes (Given): 451
Ok. You had me going there for a minute. I didn't think a 2002 came with an LCT engine. That's why I thought it must have been a replacement engine already on it. It's all good now.
post #7 of 17 Old 11-16-2019, 05:41 PM Thread Starter
Thanks (Given): 20
Likes (Given): 48
Well, brought it home today.
The motor is a Tecumseh 11 hp OHSK 110, with what I believe to be a broken connecting rod.
Time for a tear down, and see how bad it is inside.
Any comments or points of wisdom are appreciated.
post #8 of 17 Old 11-16-2019, 06:03 PM
Thanks (Given): 173
Likes (Given): 451
Usually they knock a hole in the side of the block when they let go. What makes you feel it's a rod? Not turning freely? Noise? ?
post #9 of 17 Old 11-16-2019, 06:16 PM Thread Starter
Thanks (Given): 20
Likes (Given): 48
Pulling the starter it is loose and has a knocking noise as it turns.
Removal of the spark plug and turning it over ,it has no compression.
Inserted a pencil ,it did not move while turning it over.
I’ll remove the starter tomorrow and look for a crack or hole in the case.It is full of clean oil.
post #10 of 17 Old 11-17-2019, 10:31 AM Thread Starter
Thanks (Given): 20
Likes (Given): 48
Well, I removed the starter.
The crankcase side has a bruise
Now, my waying my options. Either used motor or a short block .
