ST1032 impeller shaft end play - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 11-18-2019, 03:56 PM Thread Starter
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
I was just putting my ST1032 back together from getting a stuck rake unstuck when I noticed the impeller shaft going into the (cast iron) gearbox has about 1/4" of end play.
The bearings aren't loose - I tried tightening the adjuster on the back of the gearbox and the bearings started to bind up. And there's no sideways play, just endwise. Is that normal?
Model # is 924084 if it matters, I estimate its manufacture date sometime in the early 1990s.
ELaw is offline
post #2 of 11 Old 11-18-2019, 06:29 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
It should be Fine. (Don't Sweat the Petty Stuff, and Don't Pet the Sweaty Stuff.)
Jackmels is online now
post #3 of 11 Old 11-18-2019, 07:38 PM Thread Starter
Thanks (Given): 11
Likes (Given): 19
That's good! Because removing the cover on that gearbox is not fun, and the first time I removed it I couldn't find a way to do so without destroying it.
I wish they'd used a cover with a little "lip", like the ones used on trailer wheel bearings! Popping those off and back on again is kid's stuff.
ELaw is offline
post #4 of 11 Old 11-18-2019, 09:18 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
End play or auger shaft rotating inside of gearbox hub ??
Those nice cast iron gearboxs have a flaw... they use a 7/8” long woodruff key to transmit power from the gearbox hub to the auger shaft. Over time the key wears a slot into the shaft and allows “ play ” on the augers.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #5 of 11 Old 11-19-2019, 12:18 AM
Thanks (Given): 40
Likes (Given): 48
I've re-read the post......
Under the front large freeze plug looking cap is a small bolt that needs to be tightened, think it's a 5/16 -18. It holds the impeller input shaft into the gearbox bearing assembly. If that's what is loose. It's #16 in the pixx.
Also......
It's #19 in the pixx I was speaking of in earlier post.
~~ And Lastly ~~
post #6 of 11 Old 11-19-2019, 10:13 AM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
My 2015 Platinum 30 SHO has a different cast iron gearbox but it has the same 1/4" or so end play. That is the impeller shaft is able to move into and out of the gearbox by 1/4". This is from new and is still the same after 5 years and a lot of use. I believe the 2 gears are all steel and replaced as a set.
My gearbox appears to have a simplified number of parts compared to the diagram that @Shaw351 showed in post # 5 and it does not seem to have the adjusting feature.
Town is online now
post #7 of 11 Old 11-19-2019, 01:29 PM Thread Starter
Thanks (Given): 11
Likes (Given): 19
Yeah, that's the one I'm worried about. If for no other reason than if the bolt comes out completely, I imagine it could trash the gears.
I guess I'm going to have to deal with R&R'ing that cover... yay.
ELaw is offline
post #8 of 11 Old 11-20-2019, 12:23 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
I can't remember where I read this, but it was on the J/D version of that gear box..... They advise to replace that cover after opening it up..... Wether it gets destroyed trying to remove ( probably) or to prevent future leaks (Definitely), but for around $10, I'd save the grief and replace it
GLuck, J
JayzAuto1 is offline
post #9 of 11 Old 11-20-2019, 09:12 AM Thread Starter
Thanks (Given): 11
Likes (Given): 19
Yeah I already ordered a new cover!
I'm really not looking forward to the job though... last time I had a super-tough time getting that cover installed.
ELaw is offline
post #10 of 11 Old 11-25-2019, 07:27 AM Thread Starter
Thanks (Given): 11
Likes (Given): 19
Hey just to follow up on this... I took the gearbox apart over the weekend and the bolt that goes in the end of the impeller shaft (#16 in Shaw351's diagram above) was several turns loose, and some of the threads were chewed up.
Apparently when I fixed up the machine a couple of years ago I omitted the lockwasher that goes with that bolt, and possibly installed a bolt that was too short. Now it has a longer bolt with a lockwasher plus I put loctite on the bolt threads! With that bolt installed and tight, there's zero end play in the shaft.
And the cover was indeed a nightmare - I actually wasn't able to get it to go on. But poking around the garage I realized last time I did this I'd ordered a couple of trailer wheel bearing caps of the same size - that have the little "lip" around where they press into the housing. Using a properly-sized length of pipe to press on the lip, I installed one of those quite easily.
ELaw is offline
