Ariens Projects - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-21-2019, 07:55 AM Thread Starter
Likes (Received): 22
Ariens Projects
Figured Id share a couple Ariens Ive been working on this fall. Been doing alot of marketplace flips lately my last couple have come out pretty good. Starting the left is my personal machine: 1332, impeller modded, in the process of adding some LEDs, next to it is a 1128 Pro with battery Estart, that one sold quick. Next is a 28 Deluxe needed a good tune up and some odds n ends. Last is a ST824, the engine housing was completely engulfed in moose nests, so much so you couldnt even pull it over. It got a 212 Predator swap. Ill try to keep you guys up to date on my projects as they come along
Sent from my SM-G955U using Tapatalk
Nick Karahalios is offline
post #2 of 9 Old 11-21-2019, 08:42 AM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 276
Likes (Received): 171
very nice, thanks for the pics.
Paul
paulm12 is online now
post #3 of 9 Old 11-21-2019, 02:13 PM
Thanks (Received): 14
This is very interesting for me to see the first picture, The 1128 pro chute est probably the best chute design Ariens done. It is angled correctly so you don't have to lower the end of the chute for best projection. On models now, the height projection is ok but this doesn't mean higher is farther. So if you want to throw farther you have to lower end chute with last design. This seems to restrict some throwing distance even if it is better than not lowering the end chute, When I saw 1128 pro or other model in this series in action, The chute design seemed also to make less snow mist projection. It seemed to goe straight where you want. (more like Honda or Yamaha) Maybe some day I will be enough crazy to modify the chute angle on my Platinum 30 SHO or I will probably do some tests with fittings to verify if my thought are real or not.
legarem is online now
post #4 of 9 Old 11-21-2019, 02:42 PM
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
Hi Nick,
Just finished a motor exchange on a 1128 Pro with E start. Last fellow hit something hard, connecting rod bruised the side of the case.
Slickest blower I have had, with the onboard E start and hand warmers
Next,I guess I have do the impeller improvement.
Thanks for updates.
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is offline
post #5 of 9 Old 11-21-2019, 03:51 PM
Thanks (Received): 212
Likes (Received): 767
that ST 824 with the Predator upgrade is a workhorse...can't kill em and they seem to get on the governor when it gets deep and really sing!
cranman is offline
post #6 of 9 Old 11-21-2019, 06:05 PM
Likes (Received): 32
"Last is a ST824, the engine housing was completely engulfed in moose nests"
i put fake wolves around my blower to keep those darn moose away!
rwh963 is offline
Likes CTHuskyinMA liked this post
post #7 of 9 Old 11-21-2019, 09:58 PM
Thanks (Received): 11
Likes (Given): 34
Likes (Received): 24
Hi Nick
Great job. They all look good! Thanks for sharing and pictures
Ariens 1969 10,000 Series-- Tractor 10965 serial # 005841 with 10995 serial # 023507 Sno-Thro
Ariensboy is offline
post #8 of 9 Old 11-25-2019, 07:20 AM Thread Starter
Originally Posted by Ian Ariens 924 View Post
Hi Nick,
Thanks for updates.
I was very impressed with the 1128. I really like my 1332, I have a large wide driveway and it makes quick work of it. But that Estart on the 1128 is awesome, nothing better than walking up to a machine and turning a key, not have to worry about extension cords, ect.
post #9 of 9 Old 11-25-2019, 07:46 AM
Thanks (Given): 20
Likes (Given): 48
I do about 6 driveways at a time ,I still use my 924024 ,its a 10hp 32” about a 1978 vintage.You can use it one handed, but no options like hand warmers or a light. Built like a tank and never any problems.
It is very well balanced, and turns really easily as I leave the left hub unlocked.
I always wanted an onboard E start so I bought the 1128 with a blown ohv motor.
When we get enough snow we will see if the 1128 Pro is alot better.
