Ariens 921028 AX291 Starter Motor Removal - Snowblower Forum : Snow Blower Forums
post #1 of 1 Old 11-21-2019, 02:38 PM Thread Starter
Removing the starter from an Ariens 921028 isn't as simple as it should be, and I couldn't find and step by step info on the internet, so I figured I'd share this info.
Remove starter switchRemove fuel switch coverRemove bolts from tank shroudRemove bolts from tank shroudRemove tank shroudRemove pull starter/3 boltsRemove 4 bolts from flywheel shroudPull flywheel shroud open enough to access (2) bolts for starter motor. Remove starter motor.
Wazoo is online now
