Anyone doing pre-season paint touch ups? - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 11-26-2019, 02:28 PM Thread Starter
Likes (Received): 32
i just came into possession of a 2007 ST724. Been doing research, some cleaning and maintenance. decided to attempt some rust repair/repaint that most blowers have on their lower level, especially the buckets. kind of did a quick scrape, sand, clean, rust reformer, and several Allis Chalmers enamel coats.
going to need to let that sticky paint set for several days before putting the scraper and shoes back on.
ID:	159673   Click image for larger version
rwh963 is offline
post #2 of 13 Old 11-26-2019, 02:31 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
It usually looks worse after I do this so I just apply fluid film or similar to halt the spread. Unless the entire component can be removed/painted easily (like an auger, chute or a wheel)
1989 John Deere 1032
tdipaul is online now
post #3 of 13 Old 11-26-2019, 02:39 PM
Thanks (Given): 171
Thanks (Received): 70
Likes (Given): 1217
Likes (Received): 297
Gotta grab some fluid film on my way to work, thanks for the reminder...
gibbs296 is online now
post #4 of 13 Old 11-26-2019, 08:54 PM
Looks good. Nice job!
Wazoo is online now
post #5 of 13 Old 11-26-2019, 09:00 PM
Likes (Received): 61
Nice job! I took it a little further and sent the parts which had some surface rust sandblasted and powdercoated.
2004 MURRAY BRUTE 10HP 29"
toofastforyou is offline
Likes Sgthawker liked this post
post #6 of 13 Old 11-26-2019, 09:18 PM Thread Starter
thx.
i only had a few days to do this much. wanted to dress it up a little and try to arrest the surface rust/paint loss before winter. not even sure how much i will use it (i only use a shovel on several properties; am toying with the idea of getting a ramp hitch cargo carrier).
rwh963 is offline
post #7 of 13 Old 11-27-2019, 01:37 AM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Angle grinder with a flap wheel to bare metal then prime and paint. Just make sure that it's warm enough for the paint to properly cure (did my touchups about 4 months ago . . .).
tadawson is offline
post #8 of 13 Old 11-27-2019, 08:42 AM
orangputeh's Avatar
Thanks (Given): 763
Thanks (Received): 236
Likes (Given): 1584
Likes (Received): 1675
Originally Posted by tadawson View Post
Angle grinder with a flap wheel to bare metal then prime and paint. Just make sure that it's warm enough for the paintto properly cure(did my touchups about 4 months ago . . .).
you beat me to it. when i get a new used machine i do this when i take the augers and impeller out to service them. if the bucket come off , change the impeller bearing , weld up cracks , flap disk. ( have 3 cheap angle grinders from Harbor with different grit disks ) and go to town. almost looks like i know what i'm doing......
on a side note I use these cheap grinders a lot and as of yet they haven't failed .
"It Feels Like Beer O'Clock "
orangputeh is online now
post #9 of 13 Old 11-28-2019, 10:21 AM
Likes (Received): 6
Interesting post. I never heard of Allis Chalmers enamel or fluid film. So let me understand. If you machine is in good shape, you just spray the Fluid Film? Also, is there a spray can (correct color) of Allis Chalmers enamel??
The things I learn here. Obviously it is winter in NY. Can Fluid film be sprayed in the winter? I usually wax and spray with BOESHIELD T-9 Rust & Corrosion Protection/Inhibitor and Waterproof Lubrication.
SnowGuy69 is offline
post #10 of 13 Old 11-28-2019, 10:44 AM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
Here you go:https://www.fluid-film.com/winter-eq...-applications/
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
