In the belly of the beast! - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 11-27-2019, 01:50 PM Thread Starter
Likes (Received): 32
got around to removing the belly pan. cleaned out the old grease. lubed the hex axle and other recommended points. i guess it looks alright?
rwh963 is offline
post #2 of 10 Old 11-27-2019, 02:11 PM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1032
Looks to me like you've got a little too much of the wrong grease on that shaft. Wipe about 80% of it off. You DON'T want to have any excess grease drop down on your drive disc or rubber drive wheel.
If that's just "regular" grease you may want to switch to a light Lithium. JMHO
Maybe it's my eyes... ?
post #3 of 10 Old 11-27-2019, 02:19 PM
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
I think that is the before photo I do not see any grease????
When you grease cover that Drive wheel......If you get any on Drive wheel or friction disc put some fresh gas on a rag and give both a good wipe down.
SimplicitySolid22 is offline
post #4 of 10 Old 11-27-2019, 02:50 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
It does look like the before pic to me also.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #5 of 10 Old 11-27-2019, 02:52 PM
Likes (Given): 50
Likes (Received): 48
How's the friction disk condition? Any cracks or chunks missing?
Also check the tightness of the bolt on the Large gear. I discovered it loose on my old snowblower once.
HEY LASERLIPS, YOUR MAMA WAS A SNOWBLOWER!!!
2017 Sno-Tek
1995 Chevy K1500
1990 John Deere Hydro 175
88-tek is offline
post #6 of 10 Old 11-27-2019, 03:13 PM
Thanks (Received): 149
Likes (Received): 543
Is that a plastic gear on the drive axle?
oneacer is online now
post #7 of 10 Old 11-27-2019, 03:55 PM
Thanks (Given): 71
Likes (Given): 571
Plastic?? Please, we in the industry call it engineered composite material.
Zavie is offline
post #8 of 10 Old 11-27-2019, 04:09 PM
Thanks (Given): 63
Likes (Given): 77
No Joe....I thought it looked like glopped on grease on hexshaft as well but then I double clicked on the pic. for a close up and it is rust/dirt. So he said he greased it hence before photo....haha......oh well.
post #9 of 10 Old 11-27-2019, 04:14 PM Thread Starter
thx for the replies. i cleaned off the hex shaft (dirty brown liquid) and did put fresh multi-purpose grease on it. didn't put much on, but could remove some if recommended. i don't have any light lithium, just regular white lithium. i don't recall a specific manual recommendation.
the rubber friction disc is in good shape. it had been replaced in 2016.
yes, the large and small gears are a non-metal material. looks in good shape after 12 years.
rwh963 is offline
Likes Zavie liked this post
post #10 of 10 Old 11-27-2019, 04:32 PM
Thanks (Given): 63
Likes (Given): 77
Yeah looks in great shape. Solid! Overall looks good and tidy.....you are doing the right things to it so you should be ready to go. Check augers??? Wheel shafts lubed??? Oil changed??? Belts checked??? Skids set??? Sorry not trying to add...just reminding. The Belly is looking set!!! Make sure Drive disc and friction disc are clean before you put pan back on.
