Tried everything I know - No Forward or backward - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 11-29-2019, 08:23 AM Thread Starter
Unhappy Tried everything I know - No Forward or backward
I have a 2005 Ariens 924125 11528LE snowblower. I really like this machine. This year for some reason it will not go forward or backward like it used to. I used to put it in 6 gear and the thing was dragging me around. Now in 6 gear it won't move especially if I'm trying to blow 3" of snow. I have done the following adjustments... Change the traction belt, the friction disk, the spring on the traction handle, changed the idler wheel on the drive chain, tightened the cable from the traction handle to the friction disk adjuster, tightened the nut on the friction wheel adjuster, made sure the gear selector was at the right position and tight with the selector in high reverse for the adjustment, checked all related springs that have to do with traction. Don't know what to do now? Ant suggestions? I may have to take it in to my local dealer...
Louis G. Cote is offline
post #2 of 11 Old 11-29-2019, 09:31 AM
oneacer's Avatar
Thanks (Received): 147
Likes (Received): 538
Could only be due to a couple things:
The belt for the drive is slipping or not being engaged by the idler pulley properly, or an actual keyway issue on the engine drive shaft pulley.
The drive plate is not spinning under load, i.e. not secured to the drive shaft properly.
The friction disc and drive disc are not being drawn together properly.
The friction disc is not spinning the axle system, or both wheels are not engaged with the axle itself.
oneacer is offline
Likes aldfam4, rod330 liked this post
post #3 of 11 Old 11-29-2019, 09:55 AM
Thanks (Received): 212
Likes (Received): 767
I've found on those old 924's that the aluminum disc that rides up and contacts the rubber drive disc gets seized and doesn't ride up and contact the rubber donut when you squezze the lever. I spray the bearing with PB Blast and carefully move it up and down with a crowbar until it's free, then spray with lithium grease.
cranman is offline
Likes Kiss4aFrog, aldfam4, Shaw351 liked this post
post #4 of 11 Old 11-29-2019, 12:29 PM
Thanks (Given): 586
Thanks (Received): 765
Likes (Given): 4338
Likes (Received): 1727
to SBF Louis
post #5 of 11 Old 11-29-2019, 02:37 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
with the belly pan off, see whats happening when u engage the drive system, dont keep throwing parts at it until diagnose whats not working and the easiest way to do that is by visual inspection of the drive system when its actively engaged.
if you post a video of it doing this we might see whats wrong
MY VIDS ON FIXIN HER UP
vinnycom is offline
Likes aldfam4 liked this post
post #6 of 11 Old 11-29-2019, 04:06 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
Also, you may need to adjust the drive cable. You may not be getting enough pull, to engage the friction wheel.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #7 of 11 Old 12-09-2019, 07:07 PM
I have the same symptoms on a 24 inch wide Ariens. Model number is 920014
The traction disc was looking kind of beat up, and there was lots of rubber dust inside the bottom cover, so I replaced the disc. However, when I push down the lever to put it in gear, it surges a few inches and stops. That's what it was doing, before I replaced the traction disc, a few minutes before it failed completely. Anyway, I tried pulling pretty hard on the cable in case I just needed more pull, but that didn't change anything. I didn't hear any unusual noises while doing this. I don't recall whether it was on the auger drive or the wheel drive, but I think it used to make a little skid noise when engaging.
I suppose oneacer's advice in post 2 probably applies to my snowblower as well? I'm hoping maybe it's just that the idler pulley arm is stuck or something, so that I don't have to take everything apart.
Any advise beyond oneacer's is appreciated.
Thanks,
Lincoln
rnlocnil is offline
post #8 of 11 Old 12-09-2019, 07:52 PM
oneacer's Avatar
@rnlo,
First, you might want to check that machine, as back in the day, that model had a recall for possible fire issue, but I guess if it's fine, you are probably fine.
As far as that Friction Disc, it is the Drive Plate that is drawn to the fixed friction disc. Make sure the drive plate return spring is properly functioning, and the drive plate indeed is coming into the friction disc when depressing the handle. A cable adjustment may be required? or something maybe broke or bent?
You can look at the schematic here if you don't have the one that came with it:
https://www.partstree.com/models/920...000101-034999/
oneacer is offline
post #9 of 11 Old 12-09-2019, 08:33 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
You have to make sure the friction disk is dropping down and meeting with the friction plate.
post #10 of 11 Old 12-10-2019, 08:59 PM
oneacer:
Thanks for the heads up on the recall. I checked the serial number, though, and I should be ok. Those exploded diagrams were quite useful, and better than what's in the manual. Especially when I was trying to remember if there had been a spring at a particular spot which wasn't there any more. There was. It would have been a lot easier to find if the rubber dust on it had been a different color. However, I'll stop now instead of going into a blow by blow account.
As it turns out, the traction belt had stretched or worn so much that the idler pulley ran out of travel. So I replaced the belt. I also replaced the other belt, since I had it open. Now seems to work fine, though by the time it was fixed almost all of the snow had melted! Thinking about skipping forward to April.
Thanks to the authors of both responses.
rnlocnil is offline
