Having tough time trying to find replacement carburetor - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-02-2019, 10:04 AM Thread Starter
JnC
Thanks (Given): 69
Thanks (Received): 144
Likes (Received): 234
I am trying to help a friend fix his Ariens 924116, it seem to be having tough time starting using the pull cord; if you use the 110v plug it starts up fine but with the pull cord it takes a few tries till the machine comes to life. This would be fine if he didnt have shoulder issues, I suggested replacing the carb as cleaning the carb didnt really solve the issue.
I usually use Boats.net to find honda replacement parts and being that the GX motor is so common I have no issue finding aftermarket carbs. I have looked everywhere and all I keep finding is part lists/diagrams on partstree, jackssmall engine etc etc for the ariens and they DO NOT list the carb or the carb part number, you can buy the whole motor but cant find any individual parts.
Any idea what the part number might be for an Ariens 924116 ? It has a 10hp tecumseh L-head motor, TIA.
JnC is offline
post #2 of 9 Old 12-02-2019, 10:08 AM
Thanks (Given): 21
Thanks (Received): 17
Likes (Given): 96
Likes (Received): 78
Ebay... Sold by engine types
foggysail is online now
post #3 of 9 Old 12-02-2019, 10:09 AM
Thanks (Received): 150
Likes (Received): 543
If he has shoulder issues, He should just use the electric start and not worry about the pull aspect. That is what it is there for.
oneacer is offline
post #4 of 9 Old 12-02-2019, 10:14 AM Thread Starter
JnC
Thanks (Given): 69
When he uses it at home he does, but he plows for a living in winter time and the machine is usually in his truck and needs to be used on the properties he plows, thats when things get a bit complicated with the 110v.
JnC is offline
post #5 of 9 Old 12-02-2019, 10:23 AM
Pulling a pull cord a couple times to start is not unusual for a machine. The unit sounds fine, and I do not think putting on a new carb is going to change an already good running machine.
He could probably just get a power inverter for his vehicle, or bring someone with him, or if he has shoulder issues and can not pull a starter cord on a blower, he might consider having someone else do that sort of physical work.
oneacer is offline
post #6 of 9 Old 12-02-2019, 10:38 AM
Likes (Given): 51
Likes (Received): 48
Like Oneacer suggested---->https://www.homedepot.com/p/GoWISE-U...-306070582-_-N
HEY LASERLIPS, YOUR MAMA WAS A SNOWBLOWER!!!
2017 Sno-Tek
1995 Chevy K1500
1990 John Deere Hydro 175
88-tek is offline
post #7 of 9 Old 12-02-2019, 10:57 AM
You can get them a lot cheaper than that ...
oneacer is offline
post #8 of 9 Old 12-02-2019, 11:37 AM
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
tech carbs are about the easiest to source of any blower 14 bucks a carb max 1st you need to figure out which motor you have everything i see says its a ohv motor in that case any ohv 318cc carb will work
if its an L head any 358cc carb will work non adj or adjustable
https://www.ereplacementparts.com/ar...26_157495.html
I agree the carb is fine as other poster stated properly tuned tecs start 1/2 a pull
proper starting procedure right amount prime and choke setting should start 1/2 a pull
1132le is offline
Likes Ian Ariens 924 liked this post
post #9 of 9 Old 12-02-2019, 12:23 PM
Thanks (Given): 20
Likes (Given): 48
Fresh non ethanol gas would help or get a 12 volt starter if using the unit commercially.
Ariens 924024 8 hp 32” now a 10 hp
Ariens 910008 7 hp 24”
Ian Ariens 924 is offline
