Deluxe 28 Only Right Wheel has Power – Is this Normal…? - Snowblower Forum : Snow Blower Forums
post #1 of 26 Old 12-02-2019, 05:50 PM Thread Starter
I just picked up a 4 year old Ariens Deluxe 28 model #921022. It looks brand new and runs great. I feel sort of foolish for asking this question but when I start it and engage the wheel drive, only the right wheel (referenced as if you were standing operating the machine) has power and the left wheel is just free spinning. When I turn off the machine I can easily push and pull it around on both wheels but when operating the machine, shouldn’t both wheels have power?
White Out is offline
post #2 of 26 Old 12-02-2019, 06:04 PM
1132le's Avatar
Thanks (Received): 95
Likes (Given): 68
Likes (Received): 217
Pretty sure its a 2013 built in 2012 if so it prolly has a pin lock on the left wheel
1132le is online now
post #3 of 26 Old 12-02-2019, 06:23 PM Thread Starter
Is the pin lock on the outside of the wheel or on the shaft inside the gear box area that's accessed by removing the belly pan? I'll take some photos tonight and post them.
post #4 of 26 Old 12-02-2019, 06:28 PM
Thanks (Given): 166
Thanks (Received): 301
Likes (Given): 408
Likes (Received): 998
watch........
post #5 of 26 Old 12-02-2019, 06:58 PM
Just a question does it have a lever under the left handle? If so you have a differential lock. Give it a squeeze and it may correct the problem. Not sure of the model so I can't be sure you have this or not. Good luck.
ed in cny is offline
post #6 of 26 Old 12-02-2019, 07:07 PM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 559
Yup, prolly has Ariens 250cc Polar Force Engine By Briggs And Stratton and pin lock just as you said.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #7 of 26 Old 12-03-2019, 12:14 PM Thread Starter
I do not have pin lock holes on the shaft outside of the wheel. I have metal clips that hold the wheels on. If I remove the clips, the right wheel slides right out easily. I did this and cleaned the spindle and shaft and greased it. I never could figure out how to remove the left wheel. I could remove the clip and couldn't get the wheel off. It would move back and forth a little bit but I couldn't get it to slide off. It sure felt like there was another clip holding it on, but I couldn't find anything that needed to be removed?
Yes, I do have the lever under the left handle so I do have the differential lock but it does not seem to work. Are there pins or anything I can check inside the gear box? The cable seems to be adjusted correctly, but I will take a better look this weekend when I can see better in daylight. I can take photos of anything if that would help diagnose my issue?? Thank you!
post #8 of 26 Old 12-03-2019, 01:06 PM
Zavie's Avatar
Likes (Given): 559
Take a look at this video:
Zavie is offline
post #9 of 26 Old 12-03-2019, 01:25 PM
Thanks (Received): 123
Likes (Given): 144
Likes (Received): 283
Those wheels are keyed (ask me how I know lol) the key may be missing when you took the wheel off, oh I just seen you have the wheel lock lever, if that is not working right you can manually lock it with the belly pan off but may have to leave it locked, I had that on my ST1027LE but could not repair it so purchased a auto turn kit for it from Ariens
Dauntae is online now
Likes Zavie liked this post
post #10 of 26 Old 12-04-2019, 01:31 PM Thread Starter
Zavie - GREAT VIDEO LINK!! Thank you. That's the exactly same set up as I have on my machine. I wish he also showed how to correctly adjust the spring that the cable from the handle lever attaches too. Does anybody have a good video link of this process?
I'm planning on pulling my belly pan off this weekend and taking a better look. I'm hoping that a good cleaning and some grease is all I'll need like in the video.
Dauntae - By manually, you mean using my fingers to snap or lock PART A and PART B together correct? And once they are locked together you can't unlocked them manually with your fingers?
As far as removing both the left and right wheels, do I just need to remove the outside clips and they should both just slide off the axle/shafts? Is there anything else I need to remove to get the wheels off? I'm not sure if mine has a key in the shaft or not??
Thanks for the help guys.
