Ariens 8526 - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-02-2019, 07:50 PM Thread Starter
Ariens 8526
I picked up a pretty much brand new Ariens 8526 tonight. My question is, is the impeller suppose to turn “freely” even while the machine is off??? Or is something broken?
Model- 932105
Serial- 002972
Tecumseh- LH318SA
Not sure on the age or anything. But besides that impeller, the machine looks like it was never even touched. Like right off the showroom floor.
ntomsw is offline
post #2 of 11 Old 12-02-2019, 08:02 PM
Thanks (Received): 150
Likes (Received): 543
You can check online in that machines schematic, but most impellers are held on the impeller shaft with 2 roll pins.
If they are sheared, many times the remnants are still in the shaft. It can be worked on while in the housing, but way easier to pull the off the bucket, and take out the auger assembly. Would be a good time to also check all the bearings, bushings, and make sure the augers are free spinning and have the correct shear pins.
Just sayin ….. JMHO
oneacer is online now
post #3 of 11 Old 12-02-2019, 08:09 PM Thread Starter
Just sayin ….. JMHO
Ok, so you’re saying the impeller is NOT suppose to turn freely, and something is broken? Because I don’t see any pins at all in the IMPELLER shaft. Not auger shaft. Impeller shaft.
Augers spin freely? They aren’t suppose to spin freely.
ntomsw is offline
post #4 of 11 Old 12-03-2019, 02:13 AM Thread Starter
Anyone??
ntomsw is offline
post #5 of 11 Old 12-03-2019, 09:47 PM
No, the impeller should not spin freely. See the picture of my 8526 augers. Notice the chrome nut in the middle of the augers. That shear pin holds the auger and keeps it from spinning.
infiniti30 is offline
post #6 of 11 Old 12-03-2019, 09:59 PM
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Those are the rakes not he impeller
1132le is offline
post #7 of 11 Old 12-03-2019, 10:01 PM
Likes (Given): 68
Originally Posted by ntomsw View Post
Anyone??
You should be able to turn it by hand but with some resistance it shouldn't spin by itself
1132le is offline
post #8 of 11 Old 12-03-2019, 10:08 PM
Thanks (Received): 8
Likes (Received): 27
With the engine off, and the plug wire removed! engage the auger control lever and keep in that position (may have to have someone help you here if you don't have a strap). Then reach into the housing and see if it spins. If is does not, you should be good to go.
If it does spin, then like others have stated, the roll pins on the impeller have sheared (not likely) or perhaps the woodruff key has sheared on the pulley behind the impeller.
check this out and let us know what you found.
Robert
bbwb is offline
post #9 of 11 Old 12-03-2019, 10:13 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Auger Belt Probably Needs Adjustment or Replacing.
Global Warming is a Hoax
Jackmels is online now
post #10 of 11 Old 12-03-2019, 10:18 PM
Likes (Given): 68
Robert
it can still spin if the belt is junk or mis adjusted what he needs is resistance
someone who needs help with this prolly can't tell if the belt is adjusted correctly and think his pins are toast
1132le is offline
