Ariens 11526 Pro Model:926005 Drive issue - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-03-2019, 08:52 PM Thread Starter
Likes (Given): 14
Had a storm today the the blower started ok but when I put it in drive nothing happened. When I put it in drive I can not push the machine forward or backward with the drive engaged if I really give it a good push I heard what sounded like 2 metal plates grinding against each other. I can push the machine when the drive lever is not engaged. Any idea where I should start?
Sent from my iPad using Tapatalk
sjm1027 is offline
post #2 of 15 Old 12-03-2019, 08:58 PM
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
I would flip the blower up in the service position and take the belly pan off you can see the friction disk and see what is wrong.
Sent from my SM-G950U using Tapatalk
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
Thanks sjm1027 thanked for this post
Likes sjm1027 liked this post
post #3 of 15 Old 12-03-2019, 09:59 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
I'll take drive belt or it's tensioner for $10 . . .
tadawson is online now
post #4 of 15 Old 12-04-2019, 07:09 PM Thread Starter
Likes (Given): 14
You win. Belt
sjm1027 is offline
post #5 of 15 Old 12-04-2019, 07:13 PM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
so what was actually wrong with the belt?
Paul
paulm12 is online now
post #6 of 15 Old 12-04-2019, 07:16 PM Thread Starter
Likes (Given): 14
Ok I took it apart to see what’s going on and I noticed the drive belt was not on the pulley so the belt doesn’t look broken and it doesn’t look too worn and I’m wondering if I could just go through the season with it. Can I get the drive belt back on by loosening some adjustments and not having to split the machine in half
sjm1027 is offline
post #7 of 15 Old 12-04-2019, 09:11 PM Thread Starter
Likes (Given): 14
Nothing that I could see. It came off the pulley
sjm1027 is offline
post #8 of 15 Old 12-05-2019, 02:10 AM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Yup, poor design on those models. Belts jump off all the time.
That newer design moves the transmission pulley to the friction wheel. Nice idea as it removed friction plate assembly, and uses the lower transmission pulley surface as a friction plate surface. But the downside is the belt misalignment issue. When engine is running and snowblower is not moving there is a large alignment offset, when you engage drive lever it moves pulley to friction wheel and aligns the belt almost perfect.
Two options....
1 st... You can replace a bolt on the pulley movement plate assembly to make it more aligned when running engine and no drive engauged.
2 nd... you can cut 1/4" off of the auger pulley, file out the molded key inside, the place it on the crankshaft first and then the transmission pulley and finally the auger pulley.
Here's the pulley modification I was talking about, and if you look closely you will see where the belt had slipped off and was wearing against the auger pulley.
I'll find the pixx of the bolt replacement and post that up soon.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #9 of 15 Old 12-05-2019, 02:31 AM
Thanks (Given): 40
Likes (Given): 48
Here's the thread about this topic ....
https://www.snowblowerforum.com/foru...slips-off.html
~~ And Lastly ~~
post #10 of 15 Old 12-05-2019, 02:48 AM
Thanks (Given): 40
Likes (Given): 48
Can't find what I'm looking for ....
But here's the diagram pixx, it is plate assembly #10 I'm talking about.
It is hinged on bottom and pivots front to back, somewhere on the LEFT side of chassis there is a bolt stop, please look inside pulley area from the top and you should see the plate assembly and the stop bolt.
Let us know how you make out.
~~ And Lastly ~~
