Smart People of the Internet, your thoughts on an Engine Swap ST824? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-04-2019, 08:00 AM Thread Starter
**** EDIT*** Moved to Repower Forum... because, that is really where this post belongs... always learning...
I blew the rod in my engine during the storm yesterday... I heard the ping ping and knew I should have stopped right then and there but said to myself, just one more pass and I am done... well.... now, I am done... as the rod broke through the sidewall of the engine....
I have an Ariens 924050 028860 which has engine HM80 155128F
I found a used 924082 048855 which has engine HMSK80 155526S with a busted Auger/Gearcase
It looks like I can't just swap the 24" blower units, but I may be able to swap the engines, where the engine sheave is the same size.......
When it comes to engines, I know just enough to be dangerous, curious to learn if this is as simple as it sounds inside my head....
Last edited by TommyRockz; 12-04-2019 at 08:46 AM. Reason: **** EDIT*** Moved to Repower Forum... because, that is really where this post belongs... always learning...
TommyRockz is offline
post #2 of 4 Old 12-04-2019, 08:21 AM
Thanks (Received): 150
Likes (Received): 543
You might find some good information in the re-powering section also :
https://www.snowblowerforum.com/forum/re-powering/
oneacer is online now
post #3 of 4 Old 12-04-2019, 09:36 AM
Likes (Received): 22
I just repowered a ST824 witha Predator 212 and was very impressed with how it came out. 100$ for a brand new engine. I did need to buy a 12$ 3/4 to 1" adapter sleeve. I did this for a co-worker so i havent yet had a chance to get any feed back on snow performance, but it was an easy swap and those motors runs so **** smooth.
Nick Karahalios is offline
post #4 of 4 Old 12-04-2019, 11:35 AM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Shaft size is the probably the biggest thing you have to deal with I think (if different) between those 2 engines. usually I just buy new pulleys
e.fisher26 is online now
