Pro 28 axle bearings - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-06-2019, 05:37 AM Thread Starter
Likes (Received): 6
Looking to replace the axle bearing on a 28 pro. Anybody know the number for aftermarkets. (6203 6202 etc) I don't have the machine apart and would like to pick the up on my way home from work. Model number 926038, approximately 4yrs old. The year before the went with the square bars. Thanks
Ariens 26" Pro
HS 828
HSS724A
Something has to go!
mfrs2000 is offline
post #2 of 3 Old 12-06-2019, 10:01 AM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Hate to tell you that your machine 926038 has a plastic bushing instead of a bearing. Here's the parts breakdown, item #10.
They use similar bushing on the auger shaft, here's the modification I do for this bushing / flange setup.
And the thread...
https://www.snowblowerforum.com/foru...-bushings.html
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
Thanks Kiss4aFrog, mfrs2000 thanked for this post
post #3 of 3 Old 12-06-2019, 04:23 PM Thread Starter
Likes (Received): 6
Excellent idea! Thank you..
Ariens 26" Pro
HS 828
HSS724A
mfrs2000 is offline
