Aftermarket Belts too small? - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 12-06-2019, 04:47 PM Thread Starter
Likes (Received): 22
Needed a new belt for my 1332 so i got this Stens belt, corresponds to the correct Ariens part #, but it is Wayyy to small(short). Tried several times but it does not seem like it is going to go on. I am going to the dealer tomorrow to try an OEM belt but just hate to drive 45 minutes away. Just seeing if anyone has had a similar issue with aftermarket belts
Sent from my SM-G955U using Tapatalk
Nick Karahalios is offline
post #2 of 13 Old 12-06-2019, 04:52 PM
Likes (Given): 51
Likes (Received): 48
You can order OEM belts online,(EBAY , AMAZON, ..etc.) it would save you a trip, and even save a few bucks from buying at dealer.
HEY LASERLIPS, YOUR MAMA WAS A SNOWBLOWER!!!
2017 Sno-Tek
1995 Chevy K1500
1990 John Deere Hydro 175
88-tek is offline
post #3 of 13 Old 12-06-2019, 04:53 PM
Thanks (Given): 59
Thanks (Received): 72
Likes (Given): 58
Likes (Received): 183
some auto parts stores have a measuring tool for belts or just try to measure it yourself, inside diameter. buy a few in that range and return the ones that dont fit.
or bring old one with u to compare
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #4 of 13 Old 12-06-2019, 06:22 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Ariens use odd sizes, usually 1/4 in different between what aftermarket says fits.
e.fisher26 is online now
post #5 of 13 Old 12-06-2019, 07:47 PM
Thanks (Received): 14
Likes (Received): 24
If that is the drive belt, then yes, it is not 35" like they said. It is 35" something. Could even be 36"-37". It is also wider than what they listed. I don't know why they listed it that way. Maybe to get you buy their belt.
You could still put the aftermarket ones on, but a lot of time, they don't fit properly (hard to put them on) and would have small issues.
I was there so I know.
dman2 is online now
post #6 of 13 Old 12-06-2019, 07:50 PM
There is a specific way to put the belt on without stretching it (forcing it in). You will have to find that howto video on Youtube by yourself.
dman2 is online now
post #7 of 13 Old 12-07-2019, 08:51 AM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
Any belt that comes off, I measure it using a tailor's tape, then compare it to the length of the recommended belt. My preferred belts are Pix, D&D.
Likes Shovel liked this post
post #8 of 13 Old 12-07-2019, 09:00 AM
Thanks (Received): 150
Likes (Received): 543
Needing belts is rare for me, but my go to belt is the Gates Green Power Rated. I always keep a Gates 6836 on hand, as that is a common one for my machines. Many here also use the Kevlar Blue.
oneacer is online now
post #9 of 13 Old 12-07-2019, 10:55 AM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
I recently had a similar issue with an aftermarket auger belt. You measure the belt by it's outside circumference. As stated above a taylor's tape measure makes the job easy. I usually measure it two or three times to make sure it did not slip. You can go to an auto parts store or a store like Tractor Supply and buy utility belts in 3/8 or 1/2" widths and in varying lengths. But it is likely the OEM length is not an even number. If it is for the auger I would just get the oem and be done. For the tractor drive I often have had good luck with the Blue Kevlar or the utility belts off the shelf at TSC. They are not as a demanding application and the tensioner can make up for some slight differences.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #10 of 13 Old 12-07-2019, 11:23 AM
@toro,
You bring up a good point that not many mention, and that is the adjustment on most tension idler pulleys, which if the belt is slightly off in size, due to wear or wrong size, many times a slight adjustment at the idler will be enough to correct that. You just have to remember, if you ever change that belt again in the future, you may have to readjust that tension idler pulley.
