new ariens, starter problem - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-08-2019, 03:46 AM Thread Starter
Purchased a SHO28 brand new winter of 2018, used it twice then put away for summer. Last week (early december) I needed it and tried to start with electric start. starter began sounding normal, but before the engine caught the starter whined like it was broken, then stopped. At that point it would not respond at all when starter button pressed. Started engine by pull cord. A week later needed blower, tried electric start, it began spinning and sounding normal, then whined and quit. Nothing after that. started engine by hand.
Any suggestions? This machine is virtually brand new. Did it strip a bunch of teeth? If so, shouldnt it spin without catching? I remember the sound of a bad starter in my old pickup and this is similar,, but why the no response at all?
I suppose I will pull the starter and look. Doubtful it is under warranty still. sigh..
Sean
Sean Farley is offline
post #2 of 12 Old 12-08-2019, 04:16 AM
Thanks (Received): 99
Likes (Given): 724
i'd try lubing the drive as it's possible the armature has some rust on it under the drive gear, other wise find a automotive starter rebuilder and take it there,
not a hard unit to fix,just the brushes are one royal pain in ones stinky end when one doesn't know the tricks
87powershiftx2 is offline
post #3 of 12 Old 12-08-2019, 04:33 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
if it was still under warranty theyll probably say it was user error as to not fix it for free.
maybe just bad connection but u got to take a look at her to see whats wrong
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #4 of 12 Old 12-08-2019, 07:14 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
Sean
With Ariens 3 year warranty is seems unlikely that a 2018 machine is out of warranty unless you damaged the machine by not following the procedures outlined in the manual. I suggest you contact your dealer and see what they say. The starter could have an internal protection for those trying to start it by holding the starter button down more than the recommended 15 seconds. Did you accidentally hold the button while the machine was running? Also did you use a cord with at least 13 amps capability? Using a cheap low amp cord is not a good idea.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #5 of 12 Old 12-08-2019, 08:37 AM
Likes (Received): 32
make sure the the fuel shut off is "on".
rwh963 is online now
post #6 of 12 Old 12-08-2019, 08:41 AM
oneacer's Avatar
Thanks (Received): 148
Likes (Received): 540
oneacer is online now
post #7 of 12 Old 12-08-2019, 08:46 AM
Sounds like the starter is defective. I doubt it stripped teeth you can get a replacement for about 50 on amazon. I just did a 1971 ariens sno thro repower had the same problem once
Johnny20 is offline
post #8 of 12 Old 12-08-2019, 09:38 AM
penna stogey's Avatar
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
First post needs a hearty welcome...Hearty Welcome!
2019 Ariens Compact 24...
penna stogey is online now
post #9 of 12 Old 12-08-2019, 10:18 AM
Zavie's Avatar
Thanks (Given): 71
Likes (Given): 571
Good idea:
Zavie is offline
Likes penna stogey liked this post
post #10 of 12 Old 12-08-2019, 10:23 AM
Zavie's Avatar
Thanks (Given): 71
Likes (Given): 571
Your new machine should be easy to start.
Use fresh non-ethanol fuel
Synthetic oil that meets Ariens specs
Develop a routine for number of prime presses per outside temperature
Zavie is offline
