Ariens Deluxe 30 EFI - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 12-11-2019, 06:27 PM Thread Starter
Help Please. Brand new machine. Plugged charger into a (well hidden) connector with red/black wires; have to assume that's correct because instructions were not clear. Charged overnight, green. Put in non-ethanol gas, machine came with oil from factory. Manual says it doesn't matter what the throttle is set to, (didn't start regardless of setting). Turned starter to on position with key and didn't hear any clicking as I've seen in online videos. Used the pull and the electronic start and could hear the engine but didn't start. Feels like a disconnect between the Starter and battery?
Called Lowes and they are sending a new machine but I need to know if we've done this correctly. Many thanks for your advice.
KAD
Sharon Sisti is offline
post #2 of 19 Old 12-11-2019, 06:41 PM
Thanks (Received): 150
Likes (Received): 543
Sounds like there is something grounded … ???
Pull the plug or insert an inline spark tester to check for spark.
Regardless where you bought it, Ariens still covers it under warranty.
Receiving another one and following your same procedures may indeed give you the same results?
Did you put this together out of the box, or was it delivered to you all together as a rolling completely together?
oneacer is online now
post #3 of 19 Old 12-11-2019, 07:56 PM
Thanks (Received): 8
Likes (Received): 27
When you say you did not hear any clicking (when you turn the key), you should hear a short whine/whirring as the fuel pump builds up pressure. If you do not hear that, then the connector is not making contact or the battery is shot.
I had trouble making a good connection connection on mine. My bet is the connector is not pushed together enough.
Robert
bbwb is offline
post #4 of 19 Old 12-11-2019, 09:57 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Sorry to Hear of EFI Problems
Jackmels is offline
Likes Ian Ariens 924, Zavie liked this post
post #5 of 19 Old 12-12-2019, 01:13 AM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Yup, no noise is no fuel pump, and no pressure. Charger went green, so it would seem thr battery should be OK. As noted, make sure it's plugged back in tight, and check for lights on the ECU under the dash. Dark is a power problem. Light means thr ECU has power (and the fuel pump should, since I don't think the ECU has control of it).. Check for power at the fuel pump. If present, then the pump is bad, and if not, check the harness to the pump.
No pressure means no fuel from the injector, and no start. Likely as simple as an assembly error.
tadawson is online now
Likes Huntergreen liked this post
post #6 of 19 Old 12-12-2019, 01:45 AM
Thanks (Given): 202
Thanks (Received): 126
Likes (Given): 420
Likes (Received): 266
Make sure your fuse is installed and good.
ST1100A is offline
post #7 of 19 Old 12-12-2019, 04:19 AM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Welcome to the SB Forum.
2019 Ariens Compact 24...
penna stogey is online now
post #8 of 19 Old 12-12-2019, 09:43 AM
One thing to add (I did this too) is when it is plugged back together, it is very easy to have the pins push back out of the plastic plug...it will lock but not make connection. Pull the plug apart, move the wire connectors back into the plastic plug and hold the wire with the plug tight when you push together.
99% sure this is your problem.
Robert
bbwb is offline
post #9 of 19 Old 12-12-2019, 12:09 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
KAD
You said the light is green. In the service manual it says it should be "a blinking green LED indicates the ECU processor is operating properly" Constant green indicates low voltage or battery needs replacing.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #10 of 19 Old 12-12-2019, 01:51 PM
I suspect that the green light they are referring to is the charge complete light on the charger...not the ECU...at least that is how I took it.
Robert
bbwb is offline
Thanks Zavie thanked for this post
Likes Zavie liked this post
