airens 1128 pro will not move - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 12-12-2019, 06:44 AM Thread Starter
i picked up an airens 1128 pro model 924334 serial 001292 it will not move in any gears i checked the friction wheel which is new and drive plate moves freely what would be next to check adjustment is correct also thanks in advance
napaman is offline
post #2 of 8 Old 12-12-2019, 06:46 AM
Likes (Given): 14
Did you look at the drive belt above and below?
Sent from my iPad using Tapatalk
sjm1027 is offline
post #3 of 8 Old 12-12-2019, 06:55 AM Thread Starter
that is new also
napaman is offline
post #4 of 8 Old 12-12-2019, 08:05 AM
Thanks (Received): 149
Likes (Received): 543
If your belts are in good shape and engaging on all the pulleys and idlers, and you have a new friction disc and the drive plate is fine, with no broken brackets or springs, then it is either a cable issue or some roll or cotter pin broke on a drive gear or a gear itself, or some other drive system failure, keyway, etc......
A good inspection, searching and overview should reveal the issue, as they are pretty straight forward systems.
Photos may help as well, as saying it is not moving means it could be anything going on Ö ?
oneacer is online now
post #5 of 8 Old 12-12-2019, 08:11 AM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Does it have a differential gear?
e.fisher26 is offline
post #6 of 8 Old 12-12-2019, 08:33 AM Thread Starter
there is a clutch fork looking piece I assume should move behind the drive disc ,below the motor underneath looks like blower would have to be split to get at it
napaman is offline
post #7 of 8 Old 12-12-2019, 08:44 AM
Many repairs/inspections require a unit to be separated.
post #8 of 8 Old 12-12-2019, 05:17 PM
Likes (Given): 44
Ac pic would be good but it does sound like a roll pin or splines are missing in a gear
