Arien 30 ECL WIRING - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 12-14-2019, 01:48 PM Thread Starter
Arien 30 ECL WIRING
Just bought a brand new Arien. Iím attaching a picture. Used the top (black and red) wire to charge. The bottom 2 wires came connected. After several hours, the charger was green. I tried to start it but no luck. Turn the key and nothing happens. I checked the fuse and itís fine. Help! Thank you!
Sharon Sisti is offline
post #2 of 16 Old 12-14-2019, 01:58 PM
Thanks (Received): 52
Likes (Given): 44
Likes (Received): 71
Does it have an onboard batt? Pics of the whole machine possible?
e.fisher26 is online now
post #3 of 16 Old 12-14-2019, 02:10 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
I assume this is the EFI blower . . .
As per the manuals, there is only one set of leads from the battery, and they ship unplugged. You disconnect from the blower to charge, and considering the connector gender, etc. you undoubtably charged via the correct connector. If you did not plug it back into anything, that is the problem - that *MUST* be plugged back in to the blower to power the system, and no, nothing else gets unplugged to do so. Check your manual - there is another connector up under the dash for the battery that has not been found - might help to put the blower into service position to see better.
Best to read the manual - all this is documented.
tadawson is offline
post #4 of 16 Old 12-14-2019, 02:22 PM
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
I think the red black wires connector has to be plugged into another connector somewhere under the dash. The battery wires go to the fuse and then to the ECU harness which gets plugged into the ECU. Can you follow the wiring to the ECU and check and see if a green or red LED is illuminated? Look under the panel and then up underneath to see the LED's when the key is turned on.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #5 of 16 Old 12-14-2019, 03:03 PM Thread Starter
I put it in the service position and looked everywhere for where it would connect. I canít find it anywhere. Itís probably right in front of my face! Iíve attached another pic.
post #6 of 16 Old 12-14-2019, 03:20 PM
Thanks (Given): 71
Likes (Given): 571
What's interesting is when I look at the parts diagrams for this model there is a connector coming from the fuse/battery leads that does not show a dotted line that would connect to anything on board. So I'm wondering if that black/red connector is now just dedicated to connect to the charger. This however would conflict with the manual.......
Zavie is offline
post #7 of 16 Old 12-14-2019, 03:22 PM
Thanks (Given): 71
Likes (Given): 571
Have you tried plugging the battery charger back in to see if the charger light is green? Three hours may have not been enough time to charge even though the light was green.
Zavie is offline
post #8 of 16 Old 12-14-2019, 03:26 PM
Thanks (Given): 26
Likes (Given): 85
The manual pics show a wye in the harness with the battery connector. On the harness that is plugged into the ECU, there is a wye to the right, and there is a branch that disappears along where the red/black to the battery goes . . . might check that - they may have tucked it up in there to keep it safe in transport. The connector may not be white . . . The diagrams pretty clearly show one leg of that harness to the ECU (seen in your photo) and the other to the battery.
Manual is available at: https://www.ariens.com/en-us/manuals/download
I think yours is a Deluxe 30 EFI, which would be model 921049, and either put your serial or "123456" in, and you will get to download the manual. Check the diagram on page 13 or so . . .
Page 52 of tbe service manual has a better image - looks like the tail the battery plugs into splits out of the harness close to where the fuse comes out.
tadawson is offline
post #9 of 16 Old 12-14-2019, 03:30 PM
Thanks (Given): 71
Likes (Given): 571
Take a look at the EFI wiring diagram in the parts manual and see what I mean about what I think is the red/black wire connector.
Zavie is offline
Thanks tadawson thanked for this post
post #10 of 16 Old 12-14-2019, 03:44 PM
Thanks (Given): 26
Likes (Given): 85
Took a look, and I am pretty sure we are talking about the same thing - the leg that comes out of the harness near the ECU plug and fuse, which should have an apprporiate connector for the battery. The harness leads appear to be red/black as well, but no chance of having gotten the charger on the harness side, since connector gender will be wrong and it won't mate, so I am confident that the red/black in the photo is from the battery . . . With the wrap on the harness, I suspect that the color won't be visible other than at the connector, which I still suspect has been tucked up into the dash by the factory (why is another question, since apparently the battery lead was allowed to dangle . . . and is the one with power on it . . . ).
Harness diagram on p35 of parts makes the breakout location quite clear - right where the box that says "Service" denoting fuse info points to, and the dotted line from that leg indicating connection to the battery.
tadawson is offline
Likes Zavie liked this post
