Shifting Gears - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 12-16-2019, 12:31 PM Thread Starter
Likes (Received): 12
Shifting Gears
This might seem like a silly question but...
Can you increase or decrease the forward speed while blowing snow, without having to stop (interlock required), on any of the modern friction disk Ariens blowers?
Looking to purchase a Platinum 24 SHO and really hope this is possible. Because on my OLD Montgomery Ward blower, I have to stop any time that I want to change the speed. Would love to get a hydrostatic trans but for the added cost, small driveway and limited number of times that I use the machine, I'll stick with the tried and true friction disk.
nafterclifen is online now
post #2 of 10 Old 12-16-2019, 12:55 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
No you need to stop to change gears, otherwise you can rip the rubber off the friction disk or wear it down very quickly, this goes for all the friction disk blowers not just Ariens.
Dauntae is online now
Post Thanks / Like - 5 Thanks, 4 Likes, 0 Dislikes
post #3 of 10 Old 12-16-2019, 01:40 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
My older Ariens 10,000 would naturally pull to faster speeds if you unlocked the shift, which seemed somewhat safe, but would not easily reduce . . . so I'm going to go with stop as well. No need to drop out any interlocks, though, just release the drive clutch on the left handle, shift, and go . . . (I nlw have the Plat 24, fwiw . . .). The only annoyance is having to reach across with your left to the shifter, since your right hand is already busy . . .
tadawson is offline
post #4 of 10 Old 12-16-2019, 04:22 PM
Thanks (Given): 590
Likes (Given): 4366
Likes (Received): 1742
As stated, let go of the drive handle and then shift. Friction discs just don't hold up well when shifted under power.
Thanks eyebolt, 87powershiftx2 thanked for this post
Likes eyebolt liked this post
post #5 of 10 Old 12-16-2019, 04:47 PM Thread Starter
I'm surprised to hear this as I'm almost positive that a friends newer Toro PowerMax HD 10/28 can shift on the fly. And not that it's the same but the friction disk on my old Snapper self-propelled mower can shift on the fly.
post #6 of 10 Old 12-16-2019, 05:18 PM
Thanks (Given): 13
Likes (Given): 147
This was the last one I repaired from "Shifting on the fly" Not a good idea I would say.
post #7 of 10 Old 12-16-2019, 05:55 PM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
There was a post just a couple days ago, a new friction disk and the drive plate were destroyed in two hours because of shifting on the fly.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #8 of 10 Old 12-16-2019, 06:04 PM
Thanks (Received): 15
Likes (Received): 19
Friction disc Yamahas shift on the fly - they're designed to by using an integral clutching mechanism.
Nyah nyah nyah nyah!!!
Others?
cpchriste is online now
post #9 of 10 Old 12-16-2019, 06:05 PM
Thanks (Received): 99
Likes (Given): 742
Likes (Received): 264
my 928 max will not till the left handle is released, at that point there is no tension of the disc on the wheel
87powershiftx2 is offline
post #10 of 10 Old 12-16-2019, 06:08 PM
Thanks (Received): 149
Likes (Received): 543
Just stop and shift, …. no biggie … or shift on the fly and replace the friction disc continually … pretty simple decision in my opinion. … just sayin …
oneacer is offline
