Is the Cast Iron Gearcase for a 1032 the same as a 824? - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-18-2019, 06:23 PM Thread Starter
Question Is the Cast Iron Gearcase for a 1032 the same as a 824?
Fellow forum members,
Thank you for the warm welcome.
Have a most awesome evening!
jalessi...
jalessi is offline
post #2 of 5 Old 12-18-2019, 10:41 PM
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
I think if they are the same shape they are probably the same.Ariens only had a couple of cast iron housings that I can remember.
If you have the model #s you could double check online with your fav parts supplier.
Ariens 924024 8 hp 32” now a 10 hp
Ariens 910008 7 hp 24”
Ian Ariens 924 is offline
Thanks jalessi thanked for this post
post #3 of 5 Old 12-19-2019, 06:49 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
First post needs a hearty welcome...Hearty Welcome from the Burg.
2019 Ariens Compact 24...
penna stogey is offline
post #4 of 5 Old 12-19-2019, 08:39 AM
Thanks (Received): 149
Likes (Received): 543
@jalessi,
I don't have a 32 inch, but would think that something that much larger than a 24 inch bucket would tend to be a little more robust. …. JMHO
I will say though, those Ariens cast iron auger gear boxes are well built.
oneacer is online now
post #5 of 5 Old 12-19-2019, 11:49 AM
Thanks (Received): 212
Likes (Received): 767
If you are talking about the older ST 1032 and the ST 824 on the 924 series, the answer is no...the larger buckets had a cast iron gearbox and six blade impeller, the 24 had an aluminum gearbox and for blade impeller. The early Ariens 924's up to and including 1978 had a teardrop bucket with the older almost indestructable gearbox, that will fit on a ST 824...the SHO 24's had a cast iron gearbox and six blade impeller....I'd love to find one cheap!
cranman is offline
