Scraper Bar Sticker Shock - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-20-2019, 04:37 PM Thread Starter
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
Been Upgrading a 32" 10000 Series, And Found I needed a Scraper. Priced at $58. 95! For a Piece of Flat Metal? Instead went to the Local Metal Shop and they cut me a piece of 3/16 Stock, which I Drilled the Necessary 7 holes. Cost was under 7 bucks.
The Ignore List Takes out the Trash
Jackmels is offline
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
Thanks eyebolt thanked for this post
Likes classiccat, gibbs296, eyebolt, notabiker liked this post
post #2 of 14 Old 12-20-2019, 04:45 PM
Thanks (Received): 99
Likes (Given): 729
Likes (Received): 255
i hear you jack ,it's crazy even toro bends you over for a new one .pn 106-4573-01 SCRAPER-FIXED $67.90, plus shipping even a new scapper for my lt snow blade is a rip off for less i got a after market universal ploy snow plow and drilled it so what that it's 3/4 thick it works
87powershiftx2 is offline
Likes classiccat, Jackmels liked this post
post #3 of 14 Old 12-20-2019, 05:15 PM
Thanks (Received): 212
Likes (Received): 767
Jack...Murray or Noma scrapers are made of unobtainium, so I just go to Lowes or HD and get a three or four inch wide section of 1/8 and like yourself, make my own.
cranman is offline
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
post #4 of 14 Old 12-20-2019, 05:17 PM
SimplicitySolid22's Avatar
Thanks (Given): 63
Thanks (Received): 79
Likes (Given): 77
Likes (Received): 127
Cran...unobtainium=No longer Availium????
SimplicitySolid22 is offline
Likes Jackmels, 87powershiftx2, ST1100A liked this post
post #5 of 14 Old 12-20-2019, 05:20 PM
Thanks (Given): 63
Likes (Given): 77
Jack does Brady have this one or is the Elbow going to be an issue???
post #6 of 14 Old 12-20-2019, 05:21 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
I have done the same thing using the older scraper for the template. If you get it wide enough, you can turn it around for twice as much wear. I think 3/4" was a typo.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
Likes Jackmels liked this post
post #7 of 14 Old 12-20-2019, 06:12 PM Thread Starter
Jackmels's Avatar
I think the Locals Will Win. but it's Gonna be a Rock Fight.
Jackmels is offline
Likes Fred9 liked this post
post #8 of 14 Old 12-20-2019, 07:38 PM
Likes (Given): 729
heck what part isn't a rip off? cast iron skid kit for a toro 38801 powermax $70.00 stock ones are $16.00 each and wear out in a season unlike the ones that came stock on a powershift that lasted me 30 years
cheap and cheaper last a few years and done for. (unobtainium) GOOD one mate
post #9 of 14 Old 12-20-2019, 09:03 PM
Thanks (Given): 63
Likes (Given): 77
Agreed
post #10 of 14 Old 12-21-2019, 02:59 PM
badbmwbrad's Avatar
Likes (Received): 72
When the soles of original Ariens steel skid shoes become too thin then I cut/grind some mild steel channel material to fashion new soles. A C-clamp is used to temporarily sandwich the replacement sole onto the original sole. A wire-feed welder is then used to stitch-weld the replacement sole to the skid shoe.
A wire-feed welder is well-adapted for use on a snowblower. In addition to re-soling Ariens skid shoes, I've weld-repaired the high-stress area on an Ariens 10M6 bucket (near the scraper bar-ends). My welder can do MIG process but I find that flux-core wire is good enough for a sheet metal bucket repair or to make a fancy wingnut for the discharge chute deflector. You can find a simple 120 VAC flux-core wire-feed welder on Craigslist for well under $200 that will fuse up to 3/16" steel. It opens up a world of repair possibilities and special tool fabrication. https://boston.craigslist.org/bmw/tl...027195523.html
PS A good source of steel angle iron is to find an old metal bed frame that has been discarded.
badbmwbrad is offline
Likes rod330, RIT333, ST1100A, notabiker liked this post
