1332 shifting itself - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 12-22-2019, 09:36 AM Thread Starter
It seems I purchased an automatic shift model of ariens. It's likely and adjustment that I've overlooked but the shifter will climb up from 1st to 4th as I drive. It would be convenient if we didn't get a lot of snow that bogged down the machine. As it is, it'd be nice to have control back over the machine.
This is a used 3-5yr old model that appears to be in good shape with minimal wear or signs of rust.
Any ideas?
Sled is offline
post #2 of 17 Old 12-22-2019, 09:46 AM
Thanks (Received): 149
Likes (Received): 543
Could be a lot of things, but I would bet that a bushing, bearing or something else is amiss, causing the Disc to come into the drive plate at an angle, thus walking itself into higher gears.
You would have to look and see what is going on in there.
oneacer is offline
post #3 of 17 Old 12-22-2019, 10:16 AM
Thanks (Received): 212
Likes (Received): 767
Looks like you got to open up the belly pan and see what is going on
cranman is offline
post #4 of 17 Old 12-22-2019, 10:35 AM
Thanks (Given): 172
Thanks (Received): 337
Likes (Given): 477
Likes (Received): 836
The gear-select lever pops itself out of the slots that (I assume) are in the dashboard?
post #5 of 17 Old 12-22-2019, 10:38 AM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
If the lever on the dash is moving, unless it is different than every AriensI have ever seen, the detents are on the shifter, not in the belly, and if it is jumping between detends/positions, then the tension spring in the shifter that holds the lever in it's detent is where I would look. If the speed changes, but the lever does not, only then would I look in the belly.
tadawson is offline
Thanks RedOctobyr thanked for this post
post #6 of 17 Old 12-22-2019, 10:56 AM Thread Starter
Correct, I can watch the lever jump through the detents. I've cranked the spring down to 2/3 compressed but started to think there might be another adjustment that is out.
Sled is offline
post #7 of 17 Old 12-22-2019, 11:07 AM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
Maybe that the linkage is binding, and causing it to move, due to the tension. I'd check the linkage for corrosion and not allowing it to move freely.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #8 of 17 Old 12-22-2019, 11:21 AM
Thanks (Given): 66
Thanks (Received): 123
Likes (Given): 114
Likes (Received): 157
Agreed, but there is also the two parts of the selector rod from shift lever to bell crank. There is some adjustment where they join so if the bolts are loose then perhaps the friction wheel can move across the drive plate without affecting the shift lever position. Wouldn't need much movement in that adjustment area to change a few gears. Not sure how that would affect overall gear selection, but it would take just a few minutes to check.
Just a thought.
Town is offline
post #9 of 17 Old 12-22-2019, 11:42 AM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
With engine running .....
When you slowly squeeze down on left drive handle .....
How much downward movement happens before machine starts to move ???
Also a picture of the handle bars from the front or a model number would also help identify your exact machine.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #10 of 17 Old 12-22-2019, 11:51 AM
Thanks (Given): 172
Likes (Given): 477
Just a thought.
True, but if the shift lever itself is actually jumping between detents (per the post at 10:56), then something is forcing the entire linkage to move. Not just the lower half of the linkage (going into the belly pan) that controls the actual friction disk position.
It does sound like either the spring at the lever is too-light somehow, or something underneath the machine is really forcing the friction disk to the side, hard.
Sled, to try and isolate symptoms a bit, what happens in reverse? Will it jump from reverse 1 to reverse 2?
And if you had it in, say, forward 2, and were driving along, how difficult is it to hold the lever in the 2nd-gear position, if you slide it out of the detents? I realize it must vary from machine-to-machine. But I have a sense of how that feels on mine. If you've ever shifted on-the-fly before (while driving), you might have some context for how that feels normally, how hard the lever is pulling towards the higher gears.
