10ML35 Alive And Well - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 12-26-2019, 04:23 PM Thread Starter
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
This had to be the Easiest Predator Swap I've Done on one of these Older Ariens Machines. Factory Engine Studs were long enough, and the Chute Crank needed No Mods. Tires were from a Small MTD.
ID:	161615   Click image for larger version
"Thank You Mr. Know it All!"
Jackmels is offline
Likes aldfam4, Seaweed, Kiss4aFrog liked this post
post #2 of 7 Old 12-26-2019, 04:40 PM
Thanks (Received): 152
Likes (Received): 549
The 10000 series are still my favorites, I'll always restore them whenever I have the chance as I find them, a simple joy to work on, and the repowers work so well.
Nice job …..
oneacer is online now
Likes Jackmels liked this post
post #3 of 7 Old 12-26-2019, 06:39 PM
Thanks (Received): 212
Likes (Received): 767
Those first series are a snap.....to repower.....
cranman is offline
post #4 of 7 Old 12-26-2019, 06:49 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Very nice! Did you drill holes on the axle so that you could pin the MTD wheels?
db130 is offline
post #5 of 7 Old 12-26-2019, 06:57 PM Thread Starter
Likes (Given): 469
You Guessed It!
Jackmels is offline
post #6 of 7 Old 12-27-2019, 09:02 AM
On some of my machines, when I replaced wheel hubs, I used the ones with a keyway, and took my Dremel grinder, and put in a keyway on the axle. Just another way to achieve a new wheel setup. Works real nice on the split rim setup, using a tube. I did that many years ago on my Yardman when I wore out the solid Chevron tire, which by the way, those Chevron tread worked great.
post #7 of 7 Old 12-27-2019, 09:30 AM
Likes (Received): 28
The Dremel: Such a handy tool..
Ariens 1124DLE
(*sold:Ariens ST27LE)
(*sold: John Deere TRS21)
Toro 821
melson is offline
