Size of Ariens Pro skid shoe bolt. - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-29-2019, 07:45 PM Thread Starter
Likes (Received): 7
Does anyone know the specifications of the skid shoe bolts on Ariens Pro. I was thinking of replacing the nuts with cam levers. I would then be able to adjust the skid shoes much faster and without tools. I got stuck trying to find out the specifications of the bolts.
Øystein Eriksen is offline
post #2 of 12 Old 12-29-2019, 08:18 PM
Thanks (Given): 178
Likes (Given): 467
Likes (Received): 1047
You will not be able to get them tight enough by hand and will still need tools.
post #3 of 12 Old 12-29-2019, 08:44 PM
Thanks (Given): 176
Thanks (Received): 344
Likes (Given): 481
Likes (Received): 851
Even with some sort of cam-lock mechanism? That's how bicycle quick-releases work for wheels, and they seem to clamp up pretty tightly. With 2 clamps per skid shoe, I'd think they'd be tight enough.
Aystein, if you wanted to really make the adjustments quick, you might be able to do something like the wheel height adjusters on walk-behind lawn mowers. I have ones where the wheel is attached to an arm on a pivot, you pull a spring-type lever off of a notch, and rotate it to line up with another notch, then let it go.
I think some people have put rollerblade wheels on their blowers, instead of skids. Those might work better with the type of mechanism I'm trying to describe.
Good luck with it! Is there a specific machine you're trying to check? With the model #, you might be able to get at least the length and size of the bolts from your parts list, off the Ariens website.
I have an Ariens Pro, but mine is almost 20 years old, and things may have changed since mine, so it may not be a good reference. I've also changed over to the plastic skids, so my mounting hardware has changed, though I think they were just longer versions of the bolts.
post #4 of 12 Old 12-29-2019, 10:17 PM
Likes (Received): 50
If no one posts the bolt specs I'll check mine when I get home tomorrow and post um.
BNSFguy is online now
post #5 of 12 Old 12-29-2019, 10:33 PM
Thanks (Given): 80
Thanks (Received): 47
Likes (Given): 277
Likes (Received): 157
I haven't worked on a Pro but most of the Ariens skid shoes I've worked on use 3/8-16 x 1" or 3/8-16 x 3/4" carriage head bolts, grade 5. I keep a stock of the 1" in stainless steel....hope this helps.
I you have the specific model and serial number, there should be a .PDF parts manual on Ariens' web site.
rod330 is offline
post #6 of 12 Old 12-30-2019, 10:29 AM
Thanks (Given): 72
Thanks (Received): 123
Likes (Given): 120
I checked the parts manuals and you are correct.
The new Rapidtrack Pro and my 2015 Platinum SHO use the same 3/8"-16 x 1" for the stock steel skid shoes according to their respective parts manuals. The plastic skid shoes from Ariens comes with the same 3/8"-16 thread but a 1" and 3/16" length.
Town is online now
post #7 of 12 Old 12-30-2019, 12:49 PM
Thanks (Given): 7
My old 1336 Pro has 3/8"-16 carriage bolts installed as 'studs' for the shoes.
dernt is offline
post #8 of 12 Old 01-01-2020, 12:09 PM
Hello, could anyone measure the bolt spacing and distance from thr bottom of the housing for the pro skid shoes? Mine is 500 miles away and I need to make a new set of shoes. Of course I could have just remembered to take them home with me... Thanks!
Dmart0927 is offline
post #9 of 12 Old 01-01-2020, 01:04 PM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
First post needs a hearty welcome...Hearty Welcome....to the New Year!
2019 Ariens Compact 24...
penna stogey is online now
post #10 of 12 Old 01-01-2020, 03:06 PM
Thanks (Given): 72
Likes (Given): 120
The steel and plastic skid shoes have the same dimensions:
on 3" centers;
slot is 1" and 3/4" high at side that fits to bucket (plastic skid is wider and taller to allow for washer on outside face);
slot is 1" from bottom surface of skid shoe;
When skid shoes are new and allowing 1/8" to scraper blade the bolts fit about half way in the slots.
Town is online now
