10000 axle bushings - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 12-30-2019, 10:30 AM Thread Starter
Likes (Received): 39
10000 axle bushings
I'm assuming, based on options ect that I'm working on a 10M5. The axle is 3/4" and the hole for the bushing is 1". Can anyone verify that 05503900 is the right bushing? I got some off Amazon that claim to be the same but have a 1" axle hole.
nt40lanman is offline
post #2 of 6 Old 12-30-2019, 10:42 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Sounds like Amazon sent the wrong thing... wow, that never happens!
I've got an old PDF that says the axle bushings for that machine are part number "2X39". This document: https://apache.ariens.com/prices/newhollandxref0511.pdf translates that to 55039 which in the current part numbering scheme would be 05503900.
ELaw is offline
post #3 of 6 Old 12-30-2019, 10:50 AM
Thanks (Received): 150
Likes (Received): 543
55039 (5503900) is 3/4" ID and 1" OD.
55030 (5503000) is 7/8" ID and 1" OD
oneacer is offline
post #4 of 6 Old 12-30-2019, 12:34 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Those Are Available at any GOOD Hardware Store, 4-5 bucks. As Stated Above, there are 2 different Sizes
"Thank You Mr. Know it All!"
Jackmels is offline
post #5 of 6 Old 12-30-2019, 12:47 PM Thread Starter
Great, thank you for the advice. I just called down to my local Monnick Supply and they have them. I like supporting locals. A little pricey but not horrible. It turns out the bag I got from Amazon had a wrong labeling on one side but a correct part number for what I received on the other side.
post #6 of 6 Old 12-31-2019, 12:50 AM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Glad you found them. If they are not correct I have 8 or so here at my shop. Your not too far from me, pm me and I'll give you my address. I have whatever other bearings or bushings you might need here also.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is offline
