Problem starting SnowTek 20 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-05-2014, 10:25 PM Thread Starter
My snowtek worked fine for half a job, then after i shut it off to take a break, i came back and it didn't start. It had been working fine all winter.
I added some more gas, tried again, and No Go. Tried it again a few hours later and still no start...any advice on what it could be? I am thinking maybe the sparkplug? It is 1 year old, used last winter, and had a an oil change at the start of this winter. Could use some help. Thanks.
jerry99 is offline
post #2 of 4 Old 02-06-2014, 01:09 AM
Thanks (Received): 28
Likes (Received): 58
How did you turn it off, switch, key? did you turn the fuel valve off and let it run out?
Check the basics fuel on, key on/key in slot choke on (even if warm engine--many new epa carbs only restart with choke even when hot)
If all checks out and still no start try some starter fluid in the carb. if it fires you have a gas issue if it doesnt check for spark with the spark plug out.
td5771 is offline
post #3 of 4 Old 02-09-2014, 06:07 PM Thread Starter
Thanks, I cleaned the sparkplug of the snowtek, then put it back in. Then fired it up...it started for a few seconds, puffed out some black smoke on the side, then stopped. Tried it again and then No Go...Does that signify any type of issue?
BTW, how would you put starter fluid in the carb? I don't see a way to put liquids in the carb, but I am not educated on accessing the carb.
jerry99 is offline
post #4 of 4 Old 02-09-2014, 06:57 PM
welcome to sbf . I have a snow -tek 24. when you tried restarting it, did you use the primer. when I shut mine of to refill with gas and if it is warm all I have to do is prime 2-3 times and it will start with out choke.hope this helps.gayland
BB Cub is offline
