Ariens autoturn mechanism disassembly - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-03-2020, 10:25 PM Thread Starter
Hi from NH -
My deluxe 28 is a 2015 dealer bought and auto turn has worked flawlessly until now.
Most times it doesn’t let the wheels engage and clicks when I pul back on moving machine or when I go up an even slight incline.
I suspect the lubricant inside is dragging and causing it to not engage while delivering a click click click.
Has anyone taken this device apart to service ?
All belts and friction disc brand new.
Aussieplay is offline
post #2 of 4 Old 01-04-2020, 07:46 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Like to officially welcome you to the SBF from the Battlefields of Gettysburg, Penna. Good luck.
2019 Ariens Compact 24...
penna stogey is offline
post #3 of 4 Old 01-04-2020, 09:40 AM
Thanks (Given): 174
Thanks (Received): 342
Likes (Given): 480
Likes (Received): 849
Welcome to the forum! I don't have an Auto-Turn machine, so certainly can't offer insight into disassembly, unfortunately. But this video shows a little bit of the internals, if it's of use:
I wonder if spraying some lubricant into the unit (after shielding the rubber wheel and friction disk, to avoid making them slippery) would do anything to help, while being non-invasive. Through whatever gaps may be available.
I can't remember who makes the unit, I want to say the company starts with a G? But searching using the manufacturer name might help find discussions of disassembly or repair work. I believe they are used in machines from other brands as well, not just Ariens.
post #4 of 4 Old 01-04-2020, 10:21 AM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
https://www.generaltransmissions.com/en/products/snow/
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
